So I have never changed my fuel filter and my dad asked me if I ever done it . I was like .............. nope . Ive done all my oil changes and oil filter changes , and grease the 6 nipples by the tires. I am not sure where the fuel filter is tho. A picture or a description of where it is would be nice .
You don't have a serviceable filter. Filter is part of the fuel pump in the tank.
'04 began the in-tank units except for some flex fuel vehicles
If you were to have one it would be on the drivers side frame rail
thanks for the response. So i notice by my tank near the back of it there is a plastic cylinder what is that ?
Also why would the fuel pump be in the tank and the filter both those parts go bad and dont last forever. Sounds like a pain if they go bad.
My thoughts were the same way.. Why they didnt put an external fuel filter is ridiculous..
but txab is correct 04 and up there is none.. my 01 van an 03 tahoe have them
but nothing in the 04 tukon i had and none on this 05 sierra
That's part of the EVAP system
Txab you are a great help thanks I have no idea what a EAVP is but i will look it up . Thanks for your help and the information.
Got to love you tube If anyone else is reading this and want to know what a EVAP system is this is a good link
they did away with the filter when GM went to the return less fuel system..but nobody said you could put a factory inline filter in yourself..
Adding an additional inline filter won't do any good. the fuel would already be filtered by the time it got to it. All of the particles will still get caught by the OE one first. Then when the OE one plugs you are still SOL.
I think the idea is that being immersed in the sloshing gasoline keeps the filter sock from being clogged, I think that was the theory anyway.
  • 2 months later...
so anyone have fuel filter get clogged yet? or no worry?
I'm pretty sure you don't have one its a strainer in the tank if you got a 2006
Sent from my Nokia 5190 using Tapatalk 2
Gas is a lot better then it used to be, this combined with the return less fuel system means on average your pump will go before your filter gets clogged. That's why GM decided to do away with the in-line pump, also to save money. There are also fine screen filters in your injectors that would more then likely catch anything before it got to the injector pintle. Just run a good fuel injector cleaner like Techron or Redline every once in awhile and get your gas from a station that has a lot of business so you know the gas isn't sitting for awhile.
i had someone tell me my cats went bad because my fuel filter was dirty. havent gotten around to changing it because its seized on.
When was the change made to the returnless system?
Sent from my DROID RAZR MAXX using Xparent Red Tapatalk 2
    AidenVorpagel
    AidenVorpagel
  • Who's Online   1 Member, 0 Anonymous, 1,301 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
