Start Up Noise 2013 Sierra's 5.3 liter
I am looking into buying a 2013 GMC Sierra 1500 with a 5.3 vortec engine with 6 speed auto trans. A few of the trucks i have looked at when they first start they have a loud tick which last for about 5 seconds or so. I was curious if anyone knows if this is a sign of the dreaded cold start knock? Some of the engines are quite and smooth as can be. I know for a fact these trucks havent been started in sometime. Thanks!
  • Replies 35
Sounds normal for a OHV engine with hydraulic lifters that has not been started for awhile. The hydraulic lifters will bleed off and lose their preload. Once started it will take a few seconds for the oil to prime them and bring them back into proper preload.
My truck will do this after it has set for 5 days or longer. Once started and the lifters prime their should be no more noise or their might be a problem.
Yea, my 08 on REALLY cold days ticks for about 3-5 seconds. Always has.. My 02 did the same thing.. A coworker has a new F-150 and it has a nice knock on cold starts he says. It takes the engine a few seconds to get the "blood" flowing.
My truck is currently at the dealer now for the tick. My tick lasts longer than 5 seconds. If I were to start it and let it idle for 2-3 minutes, it would tick the whole time. Even when I start it and drive, the ticking gets louder as the RPM's increase.
This is the second time it's been in for this. The first time was the weekend before Christmas and they could not duplicate. Hopefully they can duplicate the noise and get it fixed.
Look for a truck that does not tick at start up.
The noise you described is commonly called "piston slap". The engine blocks are aluminum, and the piston cylinders are steel sleeved. When cold the dissimilar metals contract to different tolerances, so when you start the engine, hence the tick. As long as the tick goes away within a few minuets of the engine warming up, it is considered "normal" to GM. My 2001 Z28 (Sara) has the same noise @ startup. Also the injectors can cause a tick sound. The sound should not be a steady tick, it should vary, say compared to a lifter tick, which is steady and more pronounced.
Or it can be the lifters, AFM equipped or not. I won't use GM's LS7 lifters ( the lifter used in anything now without AFM) as they are notoriously noisey even with correct preload. It's common on builds where the engines otherwise make no noise beyond valvetrain until the lifters are swapped with something else and the noise magically disappears. That and I had one fall apart and destroy the engine in my 09...... which GM told me all along it's prior life it was "normal".
Something else to consider is wristpin noise from you guessed.... play in the bore where the wrist pin rides...
Buy the truck that is quiet on startup and hopefully avoid any and all BS.
I just want to say thanks for everyones input. I have come across a few more 5.3 engines with the loud tick. I have one truck that is smooth as can be but the transmission shifts a little more positive than the others. Im not to worried about the transmission. Id rather have one that is a little more positive maybe then it wont fail. Is it true that these new six speed transmission are non servicable? I am going to a few different GMC dealers today to see how they sound and feel. Ill keep you guys posted on my progress. Thanks Again!
I am not sure of what you are asking, the automatic 4L80E is fully serviceable.
My 2007 5.3l was quiet and smooth as silk. I've had my 2010 5.3l for 2 weeks and twice in that time in the morning it ticked loud enough to hear it inside my house when I use my remote starter. It went on for way more ban 5 minutes. But by the time I got to work it was a barely audible tick. I can't even hear the exhaust in my house but the ticking i hear was crazy loud. I want to talk to the dealer as it is under warranty but I'm afraid if they don't hear it they won't fix it!
Take the vehicle in at the end of the day, and let them keep it overnight. I'm sure they will hear the noise when they start it cold.
    • Getting greedy...   The AC pump has been replaced at least once per service records, and it's been recharged twice since 2018 or so, in approximately 2 year intervals between those charges.   It was done at the same shop...clearly they were enjoying the revenue of recharging the system periodically versus actually tracking down and fixing the leak. I learned that the owner was 88 years old when she passed in 2023, so maybe they assumed only a temporary fix was needed anyway.   The system is basically empty now, the compressor spins freely, so I'm guessing it "just needs a recharge".   I vacuumed it down, and it has basically held overnight. Doesn't appear to leak under vacuum, check! So it must leak under pressure. I don't have a way to pressurize the system and pressurizing it with shop air wouldn't be great for the air dryer (which is probably toast anyway?)   The dryer (accumulator? I'm not an AC expert) has a Schrader valve, but the high side has an old ball-type valve, which are notorious for leaking. It's clearly had schmutz blown out of it at one point because the line/area next to the valve is coated old black crud, which I assume is AC refrigerant residue/oil, or maybe even dirty dye. I think I'll roll the dice and replace the valves. I have a black light around here somewhere so I'll find it and shine it around the engine bay in the dark to see if there's any dye.   I can't think of another way to track down the leak other than injecting some dye (if it doesn't have any) and having it charged up. We can't buy R134a off the shelf here anymore, so I'll run it up to Jiffy Lube and have them do it. I think I have a coupon. At the very least, the charge should last long enough for a year or two, according to history. I think this truck will be long gone by then. But cold AC is a selling point.
    • Got the truck back today.  Called them yesterday to get an update, and miraculously my truck is finished?!?! The $13k out the door was complete bullshit!  Ended up being over $14k.  They added some bullshit service bulletin that I cant even find, where they replaced my radiator without telling me or asking me, and charging me for it.  Need to do more research into it, cause they leaked the first delivered radiator was ran over by FedEX.  Sounds like bullshit to me. 2.5 Months for an engine swap, which ended up being remanufactured, not new; ****ing ridiculous.  Brakes are squishy as hell, not sure if its from sitting.  Will give a couple days to see it that figures it self out.  GAVE IT BACK TO ME WITH 1 GALLON OF GAS!  Just filled the tank the day before drop off, more bullshit.  My dash cam SD card was formatted, not really much I can do about that. 3 year, 100k GM warranty at least.  Time to sell it and say **** off to GM.  Bad experience.  Cant wait for the survey email to come through.  Overpriced Raptor R, here I come!
    • If I forget the phone in the truck, and forget the truck in the phone, and reconnect.  It works great for the day.  Truck sits overnight, and the next day is a no go.  It will connect Android Auto via usb cable, but not bluetooth.   Ive tried Everything in this thread so far, and nothing works for more than a day.   I think I might have to go to the dealer and have them flash the pcm.   thanks for all the suggestions guys. 👍
    • 2022 2500HD Crew Z71 Duramax single alternator.  Recently had the primary (water pump / fan) belt tensioner pulley bearing to fail while hundreds of miles from home of course the plastic pulley melted and belt shredded which took out some wiring. Found a replacement tensioner assembly and belt to continue now would like to find a replacement for just the pulley and bearing to have a spare assembly in case of a repeat, the rest of the tensioner is fine. Has anybody here found a correct replacement part for just the pulley and bearing? Any help is appreciated.
    • +1 for the 3.0   Perfect for 1500 pickup towing duties.   Perfect engine for a 1500 pickup period. Huge torque at stunningly low RPM makes it feel a lot lighter than it is. The fuel mileage is insane for a tall and heavy 1500... 30+ on the highway. Mid 20's around town.   It's probably not perfect if you bought a 6.2 for the braaaaaaapppppp V8 noises and wrapping it out to 6k. The LZ0 acts and sounds like a small turbo diesel and there's nothing you can do to make a small turbo diesel sound like a big one, and you can't make an inline diesel sound like a V8 diesel/big Duramax. It's a different driving experience altogether.   Drive one, I think you'll like it, though...
