Chit chat
SarahsGMC
I'm going off what I've heard around the web. I've installed 2 lifts on my truck alone. McGaughy's lift is top notch. Very tight specs unlike my RCX lift. I have 2500hd springs and 6" blocks in the rear of my truck. The blocks are like I-beams lol
Sent while in 'Murica...
  • Replies 9.5k
I have 6.25" blocks in the rear and it only brought it up 3" from stock
Should be 4.25" more since stock blocks are 2"
Need a bone spur on my big toe(joint right behind the nail) "filed down". Minor simple surgery. Says I'll have to wear a boot for 3, maybe 4 weeks, depending on how it heals.
Yikes.
They say I'll need to be knocked out with assisted breathing. Last few times I have had that done I came out of it very irregularly. One time I was showing withdraw symptoms, the second time I was trying to pull a Captain America when I woke up and fly off the bed and out the door. That was minutes after a spetoplasty was finished. They said there was a LOT of blood during that incident.
Wonder what will happen with this one!
I could just try to get cortisone shots, but would rather fix the problem than patch it.
Maybe stock springs flattened out a bit? Just a guess
Yikes.
Spider-Man?
I just made 3 days without a soda. Prettg good for me
Tried twice to give it up. First time I did it halfway- none at home but I would if I ate out. That worked till like July. Then early this year I tired going cold turkey on it. That worked almost two months.
I use to drink two six packs a day, then one day my back was hurting big time till I drank some water. Im down to one a week .
Cold turkey is the way to go on pop... Over harvest it's basically what I run on, then I quit drinking it daily by just stopping for a few weeks. I probably average 2 cans of pop a week which is pretty good. It saves a lot of money.
1-2 a week is my goal. But i dont eat much as is but i do drink a lot of soda and the doctors say i need to lose weight because of my back
I have at least one a day. I drink plenty of water but sweet tea and soda still creep in to my diet. And beer on the weekends lol
    • If one can't be found, a good automotive upholstery shop should be able to replace/sew in a new panel where the damage is on the old cover. It might not be the cheapest option..
    • Does your dealer charge you for the tire rotation on top of the oil change price ?. I haven't had any service work done at my dealer yet other than when I brought it back soon after owning it to have the front end aligned to correct the steering wheel being off center a bit. Oh they called me at least twice hounding me to bring it in for an oil change and pushing a 300.00 package of oil change and tire rotation and whatever other quick simplistic checks they would do. Only going off of what a friend gets charged for his half ton for the basic oil change and its the same amount of oil as the L8T holds, it was about 150.00. Once one buys a set of tires from most shops these days or so I believe, they will do free tire rotations and some do free tire balancing as well as free tire repairs.    Certainly doing a tire rotation is no five minute job, and definitely not at home but because I run a set of winter tires on their own wheels, I swap them at home and its a one tire at a time deal because of the tire season swap although I jack up the rear and do it and drop it back down and then raise the front and do them and coordinate the tire rotation into that process for both sets of tires. I am using a floor jack though and if I need to raise both ends at once I use a couple sets of jack stands to have all four tires off the ground. I use either an air impact or battery impact and have electric impact as well so no shortage there of easy methods to spin the lug nuts, and then retorquing the lug nuts. None of it goes quick though but my wages are cheap though ... zero. I live an hour out of town, its easier just to do things like that myself than waste a bunch of time in town and having to make an appointment and probably a special trip and sit there at the tire shop waiting for them to get my vehicle in and get it done and not screw something up in the process.
    • I do have the 8 speed.  Interestingly enough, after driving my truck for the past 2 days now, I have not had the clunking issue at all!  I am beginning to think it may have been suspension/leaf spring related, and somehow when the shop put my truck on the lift to do their initial inspection, it relieved some built up tension/pressure that was causing my problem.  I swear it felt I was a bull rider on a bucking bull the way the truck would almost rock back and forth slightly before the big thud/clunk when coming to a stop.  I am hoping I got lucky here and it's gone for good.
    • Bring it to discount tire. They do free rotations even if you didn’t buy your tires there. I didn’t believe it until I tried and they did. You can tip the employee if you would like
    • Best part of this video is how it resets expectations. Wonderfully done piece. It also made clear a few points I've made from day one. Detergent oils DO NOT KEEP A MOTOR CLEAN at the recommended or longer change intervals. They just get dirty slower than a non-detergent oil and there isn't spits difference between them on this point if they carry the DEXOS license. Great thing about the license that gets missed is it assures CONFORMITY even it that means a low bar.    One thing he did not talk about that I paused on an magnified was the condition of the oil ring separator. Besides a stuck ring a plugged separator and land drain back is huge when it comes control. We see in short order improvement in control IF that is the problem.    Another item I took exception to and he did not make plain was the condition of the timing chest and under valve cover having something to do with indicating piston cleanliness. Schaeffer's Oil makes that same omission in their million mile Ford video. I'm guessing he has never torn down a Red Line HP, AMSOIL SS motor that has been on that diet from the get. What he showed in the video was a good deal of varnish. Something totally absent in Peppers 165K cover off look. I smiled because he did his at the same milage.    He also makes the mistake of assuming oil temperatures in the pan are the temperature all over the motor even though he makes note of the piston being the hottest part of the engine. that baffled me a bit.    I can tell you from personal experience and witnessing teardowns of family motors that even oils of the 1960's would keep them squeaky clean when OCI's were 1500 to 2000 miles without exception. At 3K and above you get what he experienced and the longer you leave it the quicker to gets to the junkyard.    I think his is missing a opportunity not tearing it down again when he's done killing it. Time would be his only cost.
