Chit chat
SarahsGMC
Yea I think with the AFM off, and some time to break the engine in that it would be a good running truck. The transmission felt awful though, worse than my 2011. Not sure if it just needed time or what.
  • Replies 9.5k
Does it matter if I change the valve cover gaskets after an oil change? Or should I change the oil after the gasket replacement to flush out any possible debris?
I would clean off the motor thoroughly before you go after it, it'll make the job easier anyway. Do a clean job and you should be fine
Good advice, I'll try to clean it up beforehand!
And its because in order to place a larger order from rockauto.com I need to wait about 2 weeks from now and that will be after this weekends oil change. I'm at 5k miles and with a planned trip up to flagstaff on Sunday I don't feel comfortable at all doing it on high mileage oil.
I plan on ordering the VC grommets+gasket, 2 rear inner door handle (1 is for my dads truck), door hinge pins, and idle air control valve. Hopefully nothing else comes up by then!
How long does it take BB to respond to an email? Its been about a full week?
Not sure how long it normally takes them, but don't send multiple emails. If you do their server bumps you to the bottom of the list.
Initial respond time is the worst, then after that 1-3 days for replys after the first
When I did this job for a friend on his 6.0l I changed the gaskets and then the oil. Not that it really mattered since his engine was filthy inside and out....
I need to find a fuse for my multimeter. Its been out of service for months and i need to fix it. Its bigger than normal fuses ive seen and doesnt look like glass. Where would i go?
Radio shack?
Nothing I was able to see online at radio shack
Google whatever info is printed on it. Amazon will have it as should any electrical/industrial supply place.
Amazon showed it, but it isnt a "Prime" item and they want like $40 from whoever has it listed
That is about going price for a fuse for a Fluke Meter. Makes you double and triple check before hooking them bad boys up after ya blow a few
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,144 Guests (See full list)
