cruise control
does anyone know why the cruise control on my o8 sierra all terrain wont stay on target speed ? it will drop 4 or 5 mph before it accelerates
Its how the 900 system works
Sent from my DROID RAZR MAXX using Xparent Red Tapatalk 2
I respectfully disagree, at least with my 2013 Yukon (GM900), my particular unit keeps the speed constant without variation ,unless going up a steep incline, then the vehicle will loose mph and it will "drop a gear" and compensate.
the dealer says "its normal" but it hasnt always done that .
If it helps any my 2000 would start dropping down real far in cruise then rev up high to maintain speed on even the smallest grade. All it took for me was a tune up and it stays on target now
Sent from my SGH-I927 using Tapatalk 2
Neither my 08 nor my 13 do that, they stay pretty close to target speed. Large hills can drop or raise it a couple of mph though. My 08 did intermittently start dropping out of cruise or not engaging to the point that it would not engage at all.. Of all things it was the "stop lamp switch", which is apparently common on these trucks.
My '08 acts like that. GM's cruise in the GMT900 is BRUTAL to say the least.
It only works on roughly flat ground. Toss in some rolling hills, and you might as well forget about it. I've found hitting the tow/haul button helps a lot though.....
This may be the case but not mine...............My 2008 and 2010 both stay at set cruise speed. They may drop maybe 1mph at the most an incline but never as far as the OP stated. If it drops that far, something is wrong.
I have drove a 2007 1500 VMax, 2008 denali, 2008 1500 5.3, and a 2009 2500 6.0. The cruise would drop about 3-4 MPH say going up an overpass. I'll see a 1-2 MPH drop in my 04
thanks for all of the input , its much appreciated
If I recall I had cruise control in a 1989 mustang and a 1990 olds cutlass and they both dropped a few kms below the set limit before kicking in after accelerating and coming off the peddle, I can't remember the exact amount.
Sent from my Nokia 5190 using Tapatalk 2
