23 minutes ago, customboss said:
I wanted to buy one but was vetoed for a Subaru Crosstrek Wilderness she demanded.
Wise choice
2024 Mirage G4 ES
Fun facts. This motor paired with it's CVT is spinning under 1800 rpm at 55 mph.  Doesn't reach 2,000 rpm till about 65 mph. It doesn't strain. It doesn't fuss and passes something most can't. A gas station, several of them. Will reach local Interstate speeds well before the end of an on ramp. Parks anywhere. Quite, comfortable and a joy to drive. Only moderately more affected by truck generated windshear than a Terrain and almost the same power/weight ratio. Great daily driver and day trip vehicle. And yes, not first long haul Interstate bullet choice. So what? An Avalanche/Suburban/Tahoe to run to the post office, grocery or to work 5 miles away is overkill and wasteful.
I know people in the Mirage community that routinely drive these 75 to 85 mph all day. Pull trailers with them and at least one does both.  In the five door version, use them an campers and ATV's. Service in critical medical delivery putting 300 to 400K trouble free miles over their service lives.
I have no issues passing anything I wish to pass and do so safely. How is that possible? I don't make STUPID passes.
Besides, It's cute and cheap.
  • Thanks 1
21 minutes ago, Grumpy Bear said:
2024 Mirage G4 ES
I like to bust your balls about it having a lawnmower engine but I’d have bought one.
The smallest vehicle I had with a CVT transmission was a CRV. I’d be tooling down the interstate at the speed limit and all the sudden it be spinning at 3K RPMs. If the hill was a little challenging it would go higher. That’s with 190 horsepower. The fuel mileage was the same as the Odyssey and the Genesis. V6s about 100 more horsepower and full sized. My wife in her Genesis a full size car gets 25 MPG in town its main function. With Horsepower to spare. On the highway close to 30 mpg.
The 2025 Subaru cross track wilderness doesn’t break 2000 RPM doing hardly anything
10 minutes ago, customboss said:
Honda engineering ain’t what it used to be
I have two. Both with more than 160K miles. I’m a recent fan. I have nothing against Subaru.
Well, one of my rides has a pressure washer engine. And, it`s a Honda.😉
  • Haha 1
So does my Genset
Here's one of my other rides.
2025 Subaru Ascent, with turbo
  • Thanks 2
Super Smart car
Where did the idea that a motor should be able to run 700 rpm at 80 mph no matter what the load is come from? People wank if an automatic downshifts. They wank if the CVT increases rpm on a hill, into the wind. Same people have no issue pulling down a gear or even two with a manual transmission to pass or climb a 7% grade. Do these people need a diesel electric to get happy.
BNSF Logo Photograph by Joseph C Hinson - Pixels
Tell me. What road motor can utilize direct drive?
How many can pull a 0.55:1 overdrive cleanly at 60-70 mph?
Raven can. It's geared taller than Pepper!!
Did we forget what the purpose of an transmission is?  3A92 Mitsubishi motor has the same power of a 1933 Ford 221 CID flathead at about the same piston speed and that motor built America. :idiot:33 Ford pickup weight about the same as a Mirage too.
Some hate makes no sense even to the senseless.
  • Thanks 1
Susan has a used 4xe, last fill up using Fuelly it showed 84.3 mpg.  It's a perfect vehicle for around here.  She fills up about once ever 9 weeks.  Runs mostly on electric.
  • Thanks 1
I’m curious. Some of the advertisements I see with plug in hybrids are you may never need the gas engine. Is there a timer or mileage when the gas engine comes on to keep it viable?
    AidenVorpagel
    AidenVorpagel
  • Who's Online   3 Members, 0 Anonymous, 1,347 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
