Great looking truck! Do you rub at all?
also wanting to know if there was any rubbing. Also how is the ride
Fabtech 4" lift, 295/60/20 trail grapplers on 20" BMF REPR's
want my setup like this. How is the ride, bouncy smooth etc...? Also was there any rubbing
20x9 not sure on backspace. Thanks for the info.
Just checked, a 20x9 at +18 offset is 5.71" backspacing so you should be able to fit the 35" on one of those kits :thumbs:
EDIT: honestly I don't think you'll get a response from Brettles. I tried PMing him a few times in October and haven't heard from him. Also I don't think he has posted in several months. And he did have to do a fair amount of trimming if I remember correctly. Pretty sure I've seen pictures of the trimming somewhere on here
Edited by Mike1220
ok Ya his 295 60 20 tire is about 34" which I like the look. So maybe if I go with at least a 4.5" lift I'll be fine
Sent from my iPhone
using Tapatalk
Sent from my iPhone
using Tapatalk
I've got the Zone 4.5" lift with 295/60/20 20x9 and -12 offset. only rubs when backing up. but if you had a positive offset you probably wouldnt have any problems. the ride is a little more firm than stock but not rough by any means. bds makes zone so still a good product. and cheaper. i'd recommend it! hope this helps ya!
Currently have 7 inch Rough country lift on my 2014 Silverado. Local guy has a set of used fabtech coilovers 7-9 inch which were for 07-13 with very little use.. Would this setup work on my 2014 and would it improve ride over the strut spacers ? Or would it just be a waste of 500$?
I tried searching, but has anyone installed a Ready Lift 4" SST lift kit on the new 14s or 15s? I'm looking into a lift but don't really want to cut the frame.
I know iicoolbreeze has one on his Denali. Try messaging him.
how much u think about hat 4.5" zone will cost
Sent from my iPhone
using Tapatalk
u probably posted but show me a pic of your truck
Sent from my iPhone
using Tapatalk
I took my rc3.5 off, and did the ready lift 4 SST. Much smoother over speed bumps.
You have any pictures?
Is there any lifts that do not require modifying the truck, basically so I can return to stock. I'm looking for a 4" lift, someone said pro comp but I read it does require cutting. First time posting, been lurking for the past two weeks.
Sent from my iPhone
using Tapatalk
I think I got the kit and installed for 1900. This is the best pic I've got for now.
    Chris80s
    Chris80s
  • Who's Online   4 Members, 0 Anonymous, 941 Guests (See full list)
