BDS will allow you to use stock 20's with their 6" lift and the 4" too. I have had extensive conversation with them about it because I want to use 35's as well, but haven't decided on the 6" or 4" yet.
I am also going the same route and talked to BDS a few times. The BDS installer was insistent I needed aftermarket wheels. I just ordered Mickey Thompson ATZ P3 35x12.5r20 and ordering the BDS fox coilover lift tomorrow and keeping stock 20inch wheels.
I payed 1900 for my 6" Fabtech installed. This was what my truck looked like all those months ago back in October ;)
gatoroi: $1900 installed for a 6" Fabtech?! Are you serious? My local shop wants $3k!!! Where do you live bro? Must be cheaper living out where you are. These California prices man..
My ride, '15 Silverado LT Z71, 6" Fabtech, 35" x 12.50" 20 Toyo AT II on Fuel Mavericks, 20" x 9" (5" BS). Fits in 7' garage (82 1/2" actual opening height). I have about 1" clearance at top of Onstar antenna, had to cut the radio antenna about 6"-7". Color is Slate Gray Metallic.
Man, I'm ready to put a lift on my truck, but I didn't want to go with FabTech cuz it's like $600 more than the Zone Lift. I can get the Zone for $899 online...the Fab is like $1600 (for the 2WD). That said, I'm not doing it unless I know it can fit in my local carwash. I got a deal there for unlimited washes for $19.99 per month, and I love to keep my baby CLEAN! Over there, the max clearance is 83". The Zone Lift is a 6.5" and not a 6" like the Fab Tech. You think if I put some 35"s on with the 6.5" Zone Lift it'll sit just as high as yours? That would give me 1/2" clearance if my math is right!
Mike, It's hard to say for sure what your actual overall height will be. Each lift manufacturers claimed and actual lift height will vary slightly. In addition, not all 35's are created equal. Overall tire diameters vary between brands. Your math is correct, but keep in mind there are other variables. Good luck with your decision.
Edited by bkdR1
Height will be a huge issue but don't forget about your tire width. A 12.5" tire will not fit on a car wash track.
It fits on miiiiiine....my carwash doesn't have a typical track. It has a conveyer...super wide belt too! :)
That's awesome, wish someone around here had one like that.
Hey everyone, new to the site but I have been looking around for about a month on ideas about my truck. I have looked around alot on here, but not everything. I have a 2014 Silverado 5.3 4x4 (not a Z71) 1500 crew cab. I have a leveling kit on it right now till my tires are out then planning on getting wheels tires and lift. I want to go with a 6in lift but havent seen much other names besides BDS, Fabtech, and Rough Country. Is there any problems with a 6in Pro Comp Lift? To specify, Im thinking of the kit with a coilover shocks. Im not trying to go cheap, I want it right but I see nothing about Pro Comp and just curious. Thanks!
I'm no expert by any means, but I've heard good things about all those lifts (including Pro Comp). Heard a couple negative grumblings about Rough Country though..
I agree, I have heard of one negative about Rough Country. I have just noticed Pro Comp is just a little bit more resonable on price. And Im just like alot of others that would prefer a good quality lift and also be economic about it.
    Randy Ginoza
    Randy Ginoza
  • Who's Online   5 Members, 0 Anonymous, 1,931 Guests (See full list)
    • Paid $2.72 for E85 today.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
