My ride, '15 Silverado LT Z71, 6" Fabtech, 35" x 12.50" 20 Toyo AT II on Fuel Mavericks, 20" x 9" (5" BS). Fits in 7' garage (82 1/2" actual opening height). I have about 1" clearance at top of Onstar antenna, had to cut the radio antenna about 6"-7". Color is Slate Gray Metallic.
Truck looks awesome! You should replace your atenna with a shorty from xtenna on Amazon. Awesome atenna with great reception and only $17.
2014 Silverado 1500 with 7 inch rough country lift. 20x12 -44 fuel hostage with toyo mt 35x12.5r20. Ignore the dirt and salt, haven't had a chance to wash it.
Does anyone have any example pictures on how they trimmed their wheel wells on the cab? Only examples I can find are on older truck that don't have the extra plastic piece. Thanks
I can post some pictures for you when I go to lunch today. I had to do quite a bit of trimming on mine 13.5" wide tires and -24offset
Yes please post some pics when you get a chance
Crap I totally forgot to take the pictures. I'll take a few in the morning!
2014 Silverado lt
4" skyjacker lift
Stock wheels with 295/70r18 cooper st maxx
  • Like 5
I'm going to ask this question just to clarify, I am thinking about running the Zone 6.5" with 18"x9 wheels. Now the lift calls for 5-5.25 Backspace. I assume that means no more than 5.25"...? For example I found a wheel that I like with a -12 Offset so roughly 4.5" Bs. That should work correct? Any input is appreciated. I know this was probably answered before but couldn't find a definite answer. Thanks
Yes. That wheel should work fine with that lift if yiu stay with a 35x12.50 or smaller
I always come here in hopes that I get to see someone who did a proper 2-3" lift. All I get are 6"+ lifts lol.
Try the level thread. Good stuff in there with smaller lifts
There's no such thing a proper 2-3" lift. At that height it is just a level kit which is essentially spacers 9/10 times. Your best bet would be that Rancho Quick-Lift. It levels your truck but does it by replacing your factory strut assembly with new ones. Thus your ride quality won't suffer.
Here are the pictures. Let me know if you need any in particular.
What about something like this? http://camburg.com/all-products/07-11-silverado/fox-chevy-1500-4wd-07-13-factory-2-5-kit/
$2,500 for only 2.5" of lift?! If you are gonna spend that then go the extra step and just get a BDS coil over 6"
Not trying to be rude or anything but good luck trying to find someone who dropped that much cash for only 2.5"
