On 10/17/2017 at 7:21 AM, jimmyboy8301 said:
Zone is much better. If you don’t have stamped steel control arms you won’t need any spacer. Also make sure the spacer is lug/hub centric
2017 Chevy Silverado LTZ Z71 6.2L
4.5" Zone
22x10 AF Grips
33x12.5 Nitto Ridge Grapplers
Instagram @wildchevys
So you think the cast steel should be ok without spacers and the stock 20s?
Yes
4.5" Zone
22x10 AF Grips
After doing some research I noticed that Zone lifts push the front wheels out a bit, regardless of offset/backspacing. Anyone have input on whether or not BDS does the same? I am really anal about stuff like that and don't want to have to add spacers to my rear wheels to make them even.
Any help would be awesome!
BDS does also, in fact most all knuckle lifts do. BDS/Zone pushes the front wheels out 1.5” per side
4.5" Zone
22x10 AF Grips
So no matter what I'll be getting spacers if I want it even?
Pretty much. I believe CST is one of the only kits that doesn’t increase track width
4.5" Zone
22x10 AF Grips
Rough country sells “bracket and knuckle lifts”. A bracket lift is more money but doesn’t widen your front end.
The whole “lifetime warranty” on BDS and Zone is kinda nice..... lol
edit: Aaaaaaand rough country has that too! High five!
Edited by FootballCoach53
Does anybody have pics of 2014 or 15 Silverado with a 4.5 in zone lift and 295/60/r20 and if so info on mpg
BDS and Zone are better kits
4.5" Zone
22x10 AF Grips
4.5" Zone
22x10 AF Grips
That I agree with.  I'm not planning on beating the ever-loving piss out of mine.  However, I don't want a crap lift.  That said, I haven't seen anyone that has RCX complain about it, and they also have a lifetime warranty.  I have it narrowed to BDS/Zone or RCX. Now I just need to decide if I want to go with a bracket lift or a knuckle lift.  I just started doing my research on the bracket and have read both good and bad things about them.  I've also read good and bad things about knuckle lifts, as well.
Knuckle lifts hold up longer in the long run. Just run Bora 1.75 or 1.5 spacers in the rear and you'll be good
Sent from my HTC 10 using Tapatalk
So bracket lifts don’t last as long? And I’d need a new driveshaft with a bracket lift, right?
Why do you have to run spacers? I don’t have them on mine? Honestly, I thought it would bug the crap out of me. It isn’t as bad as you think it’ll bed. Doubt anyone would ever say anything about it.
It looks like it’s dog tracking without them
4.5" Zone
22x10 AF Grips
    • Maybe.   Maybe.   I don't want to be the one that needs help and can't get it when I need it. That is a legitimate complaint, and how they respond to those legitimate complaints is a big red flag to me.   I don't care how good the product is their conduct is subpar. Some people are fine supporting that for the sake of getting the product they want. I'm not.   To be fair, I haven't seen or touched their product in person to determine for myself the quality of it. I'm not offering any opinion on that either.
    • So if you do nothing and they act on their threats like death to America or Israel. And possibly a nuclear war. Whoever survives wonders why didn’t they listen? Or we do something like every President has said they can’t get a nuclear weapon. We’re at the 10 yard line and it happens the time is now or never. I think I’m ok with paying a little more for gas for awhile. It’s a shame that we now live in a world that’s so polarized.
    • 4-5-6 fails due to design.  Not enough clutches and not enough piston to clutch surface area.  Also the backing plate can bow.     I'd say converter is two part.  The design of converter chosen, and factory tuning of it aka slipping it in D (also L6) for AFM purposes, as well as locking it up in 2nd gear, sometimes 1st, also it will partially lock up at light loads.  All because CAFE/fuel economy requirements.  A billet converter on the stock tune might hold up better, but would still be subject to the stock tuning and how its designed to lock or partially lock.     The most baffling part to me, is the 2007-2013 6L80s didn't have the failure rate the 2014-2018 ones do.  I've been where I work for almost 17 years now, and I recall maybe 3 or 4 of the 07-13 transmissions getting pulled for something.  14-18 on the other hand, it was at a minimum one a month being opened up.    If I had to guess, I'd say the tuning for the gen 5 engines/6L80 setup and its fuel economy goals had a good bit to do with it.  Also, it was bankruptcy time during these years, so I'm thinking some cost cutting was done for the launch of the K2XX trucks.  See also now the 10 speed valve body issues (more cost cutting).  They blow out some mesh screen in the spacer plate, undersized check ball, and the feed limit valve was aluminum and wears out prematurely.         I don't think it was the HP jump from the gen 4 to gen 5?  The 6.2 in the 07-13 trucks was good for 380-400hp during its life/states of tune, and the 5.3 did 310-320hp.
    • All this might be worth it had we actually recovered enriched uranium, a WMD, or an actual nuclear deal with oversight. This is a flub of epic proportion, and they all know it.   $5.10 at a station reporting $4.99 last week. Here we go....
