5 hours ago, pineland said:
Did it kill your power? 3.23 gears? I know those tires are heavy.
Not too bad. I have the AFE intake and Chevy performance exhaust so I didn’t notice too much of a drop. I keep it in Auto instead of 2wd and it helps (more MPG as well).  It has the 3.23 for now. Looking at a gear swap and a tune.
I was considering going with a 295/60R20 which is a little shorter and a little more narrow than the full 35/12.20/20.
How can you tell which control arms you have?
2017 Chevy Silverado LTZ Z71 6.2L
4.5" Zone
22x10 AF Grips
33x12.5 Nitto Ridge Grapplers
Instagram @wildchevys
4.5" Zone
22x10 AF Grips
Thanks, dude.  I will have to take a look after work.
Cast and aluminum can run stockers, stamped generally can’t
2 Chevy Silverado LTZ Z71 6.2L
4.5" Zone
22x10 AF Grips
Now I'm curious. How does the material of the control arms affect whether or not you can use certain rims?
It’s the design, not the material. Each material has a different design
4.5" Zone
22x10 AF Grips
4.5" Zone
22x10 AF Grips
Knew about the three different materials, the different design i didn't know about.
Thanks!
Thanks!
[emoji1417][emoji1417]
4.5" Zone
22x10 AF Grips
Looks great! I just traded in my 14' for a 17' with the same 20's and am thinking either level or lift. On my 14 I had a 4.5 inch lift with 35's Nitto ridge grapplers. No rub. Ride quality was ok. How's the ride quality with the rancho lift and stt pro tires? Thanks!
Edited by Beefjr
Turned out exactly as I envisioned. 6" Rancho, 35/12.5/20 STT Pros; no rubbing.
That's exactly the look I'm after. I have a 3" rough country lift but need just a couple more inches to get the better tires.
Thanks :thumbs:
Ride quality didn't suffer much, I ended up going with some upgraded rancho rears and it's not too stiff.... and road noise on the pros is manageable.
