3 hours ago, jimmyboy8301 said:
Id run a quality tire such as nitto, toyo, or bfg, not a lot of those cheap tires that are out
2017 Chevy Silverado LTZ Z71 6.2L
4.5" Zone w/ Bilstein and Fox
22x10 American Force Grips
33x12.5 Nitto Ridge Grapplers
Instagram @wildchevys
Ya I am not a big fan of those cheap tires either, definitely planning on running some Nitto’s.
2 hours ago, mrskiff said:
Im running an 18x9 -12 with a bfg ko2 285/65r18. Looks good with a bit of stance. I have a 2.25 level
Sent from my SM-G950W using Tapatalk
Thanks for the input, Could you share a pic of your truck? Did you do any trimming or have any rubbing?
I never did any trimming. It will just barely touch when im reversing and turning hard but barely. Here are some pics from a while back.
18d0127a757a8ea194ca4d1ef5a87a1c.jpgeab38849bf8c5c5c9a680f8e9d3cd015.jpg2bdf3983dbf031c9316fb4080aaa8471.jpg
Thanks for sharing your setup. Are the tires flush with the upper part of your wheel wells or does it stick out a little?
Awesome, that’s about what I am looking for as far as how far it sticks out. Thanks for the help!
Hey guys,
How are you jacking up your lifted trucks? I have a 2016 Silverado with a 6.5 inch zone lift and my jack fully extended doesn’t lift the truck high enough for the tires to clear the ground. Thoughts?
Hey guys,
You buy a extended jack and carry it with you.
You could use blocks of wood if needed but I wouldn’t trust.
1 hour ago, arkenzo said:
Hey guys,
U have a full size spare?  It fits underneath?
Is this what you use or just second hand info?
Hey guys! Who is running Bora wheel spacers on their truck with a Zone 6.5” lift? What size spacers are you running so the track width is the same? Can you share some pictures?
Thanks!
Thanks!
I have 1.75” bora’s
5 minutes ago, jimmyboy8301 said:
I have 1.75” bora’s
No trimming of the studs correct? They just bolt right up correct?
I don’t need spacers with the Fabtech Gen 2 6 inch lift! Kept track width stock! Killer!
No trimming with 1.75”
I just wasn’t sure if the 1.75”would be too much. I thought the 1.5” would match the front perfectly but someone told me that with 1.5” need to trim the studs.
    novdelta27
    novdelta27
  • Who's Online   5 Members, 1 Anonymous, 445 Guests (See full list)
