I just put in the Sylvania Zevo 921's in my backup lights last night and also put in the 124's in my license plate connectors.......wow!  What a difference these bulbs make.
Just swap out the original bulbs to these, that's it?
Replacing the backup light bulbs is one of the best inexpensive things I've done to my truck. I found some on Amazon 1400 lumen and I cannot believe how bright they are and how effective they are for backing up to my trailer Etc.
Here is another added reverse light option.
https://www.rigidindustries.com/led-lighting/20641
These will get mounted inside the rear bumper steps at an angle. Few people have done it already, there is a post about it on this forum.
I have a shell on my truck so I find that bumper step worthless except for putting in a light on an angle and I cannot believe how bright the rear cornering light is when I'm plowing. Little things that make a huge difference. You can find a much cheaper LED spot or flood light on Amazon. About $20 a piece instead of the 120 for a set of those other ones you posted
These bulbs are super bright super cheap and appears to be very good quality01ea511bc3178176195da9586c1b77a4.jpg
These show fitting your 2015, but not my 2018 LTZ.  Anyone know what changed?
Do those bulbs fit in the center lights for shining on your bed? Can't find what size that is.
If you're referring to the ones that Kubs posted, yes, all the bulbs in the high mount brake and cargo light assembly are 921s.
  • 3 months later...
I’m sure it’s in here somewhere, but I can’t find it. LED bulbs for plate/cargo and reverse, do I need can-bus bulbs? I get all my led lights from superbrightleds.com however they offer normal and canbus for my truck (15 Sierra Denali)
I used Sylvania Zevo's from Autozone.
Plug and play. No errors.
I've been researching this all day and my head is swimming with numbers.  I just took ownership of a 2018 LTZ with HID's and LED fogs that I am perfectly happy with.  I want to swap all the remaining external lights that I can with LED.
I was researching the Zevo's but I see a lot of people saying they aren't as bright as the incandescent bulbs for the brake/turn signals.  So, I'm throwing this out there.
What bulbs do I need to replace ALL the external turn/brake/park/cargo lights with LED and have them be bright and not need resistors.
That said, I've pretty much settled on the 921 Zevo's or the 921's someone posted on the previous page from amazon for the cargo/reverse lights.  I'm really looking for good LED bulbs for turn/park/brake, but I'm willing to let someone convince me otherwise on the reverse/cargo too.
Don’t know if this is the right thread but I am looking to get a black headlight with factory bulbs no leds or HIDs looking for suggestions
On ‎6‎/‎21‎/‎2013 at 12:57 PM, MotoMedic said:
Fog Lights: LED Bulbs / LED Lights http://www.gm-trucks...g-bulbs-lights/
DRL's: Disabling Daytime Running Lights http://www.gm-trucks...ing-lights-drl/
DRL's: Aftermarket LED's http://www.gm-trucks...ng-lights-drls/
Does anyone know the complete URL for these topics? I cant seem to find them...
I have Zevos in my license plate lights and they are great.
I also have them in Cargo light and reverse backup lights and i like them.
They were in stock at either Autozone or Oreilly. Some ebay or other vendor led lights seem like they may be brighter or even too bright, but the Zevos are better than stock halogens IMO.
    ChristopherDobson
    ChristopherDobson
  • Who's Online   0 Members, 0 Anonymous, 1,122 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
