I’m trying to find a good set of 5000k (white color) headlight bulbs that I can replace the stock with that is no hassle. I don’t know about HID/LED/halogen. It is for a ‘14 Sierra SLE.
I want to avoid the blue light.
I have 2 brand-new sets of Morimoto Sierra HID kits 5k I bought for 2 of my trucks. We traded them in and now I'm stuck with them.. be happy to make you a deal on one.
So, looking for some help. I recently got on superbrightled's website and loaded up my cart with bulbs for my "new to me" rig. I ordered a HB4 led tower and just assumed that it was an easy replacement. Here is the link....
https://www.superbrightleds.com/moreinfo/daytime-running-light-bulb/hb4-led-fog-lightdaytime-running-light-bulb-28-smd-led-tower/1277/2952/?year=2015&make=31&model=1489&scc_id=1392
Got behind the actual headlight assembly and cant really see where the hell this is supposed to go. Any guidance? All the links on this post on the first page are broken.
  • 6 months later...
So apparently, I jumped the gun on replacing my reverse lights in my 14 1500 LT. I replaced with the these Zevo 921s ( https://www.sylvania-automotive.com/products/interior-and-exterior-bulbs/zevo-led/921_zevo.jsp )
Now when I reverse instead of weak yellow light from the halogens, I have these striated reflections of light and dark and can see even less! My mistake, I guess the shape of these projects directly outward instead of into the reflectors.
Is there anywhere else I can put them that they would be of better use? Cargo lights? License plates?
On 9/8/2018 at 12:08 PM, Sierra Dan said:
I have Zevos in my license plate lights and they are great.
I also have them in Cargo light and reverse backup lights and i like them.
They were in stock at either Autozone or Oreilly. Some ebay or other vendor led lights seem like they may be brighter or even too bright, but the Zevos are better than stock halogens IMO.
Did you use Zevo 921's in the reverse lights? I put some in and they are throwing the light in a weird way, shadow lines from the lens or something...
I would not confess that the zevos are better than say other 921s you can get online based on some pics and reviews read within this site. Yes they do bring out the "lines" from the clear lens but then again i remember my halogens did also.
The same bulb works in the cargo lights.
I have the same set you linked to above.
Just upgraded the HID's in my 2016 Sierra. I installed the Morimoto D5S HID bulbs. They are so much brighter than the stock Philips bulbs.
  • 8 months later...
I’m replacing all of my lights with led bulbs in my 2014 Silverado. How many resistors do I need to order? Since I have 8 lights that blink do I need 8 resistors so each bulb has one? Thanks
  • 4 months later...
I thought I saw this somewhere but now I can't find it....
Is it possible for the license plate lights to be too bright?
They basically point right at the camera which makes me wonder if they can overwhelm it.
I am asking because when I back up at night it seems washed out, when I back up in the day it seems much better.
When I tap the breaks it also looks better which makes me wonder if a less powerful LED would be better, I want the clean white light just not as much of it ?
I just think the camera is garbage.  I have the stock license plate lights but have the Putco bar with reverse lights and it washes the camera out at night too.
I have a 2015 Chevy 1500. Has anyone had issues with the 9005 not fitting in the housing? I replaced my low beams with the Auxito Led brand and absolutely love them but went to install the hi beams and it does not fit in the housing? any suggestions? Yes it is a 9005 bulb
  • 2 years later...
I came on here to research this exact same issue. My factory bulbs had a dab of paint on them, which shielded the camera from the glare. Been trying to find an economical solution for awhile myself.
    • A while back, my truck (2018 GMC Sierra 1500 5.3) went in for an o2 sensor and routine service. The tech identified that my rear output seal on my transfer case was leaking, and recommended I have them replace it. At the time I didn't think anything of it, and had them do the repair. Less than a month later, I noticed that the recently repaired seal was leaking again. I called the shop that did the repair and they warrantied the repair and replaced the same seal again. A few months later, I noticed that once again the same seal leak had come back. It wasn't a great time to bring it in and I ended up just living with it for 6 months or so, noticing small (smaller than a baseball) size oil stains below the truck when it would sit for a while, as well as oil spray on the frame (to the point where it actually took the underbody coating off in that one spot). Finally got around to brining it in again, but this time I took it to a dealership service center since I am in a different part of the state for school. They identified the same output seal leaks and recommended they replace them. They also said there was no scoring on the inside of the transfer case, so it didn't need to be replaced. They chalked up the original repair failures to non oem seals and a job that wasn't done correctly. Now they called and said the seals are holding after driving/sitting for a while, but they found a very small leak in the middle, that they recommended they seal with some kind of silicone/jb weld (not sure what they are using). I haven't picked up the truck yet, but I have been reluctant about this whole repair process because I feel like they are just fixing the same thing that keeps coming back, and I am concerned there could be another root cause for the seal failing. Has anybody else experienced anything like this, or have any ideas on other things that could be the root cause?
    • I just started having AC issues with my 2012 Sierra. The symptom is blowing warm air on all vents.  Here is what I have checked so far. Compressor clutch appears to be engaging and cycling  I checked all fuses and relay, no issues. The only thing I have notices is the short line that comes from the firewall is very cold / frosted. This line is approximately 12 inches long. The coldness stops when it hits the first line connector. As far as AC compressor - At first start the clutch engages, runs continually, Short AC line frosts up. After idling for several minutes the AC line thaws out some but is still cool and the compressor clutch starts cycling on and off every 5 seconds.  Any suggestions on what to look at next would be appreciated.
    • Unless you are using a bypass filer system with a Beta of 1000 at 2 micron the commercial filters we have access to, even the very best of them, are poor at the 5 to 10 micron range the typical UOA test can 'see'. Point is there are some truly awful filters being sold A 45 micron Beta 75 filter is what Dyson used to call a screen door on a submarine. That leaves wear metals disconnected from filtration unless particulates are larger than the test can 'see' and yet captured by the filter...which is its job. If that is true then you have a major issue screaming at you.    The graph isn't mine. It belongs to GM and their study on this area. I looked up those studies and provided those SAE tech paper addresses multiple times. Machinery Lubrication displayed it and confirmed it. So if you have doubts about the study you'll have to take it up with GM Engineering. Just like you would have to take up a difference in opinion about the meaning a word with Webster or the length of on inch with the National Institute of Standards and Technology.      Most manuals have two schedules. "Normal Service" and "Severe Service". On it's face it tells you that oil in severe service is more highly stressed and doesn't "Last as Long". The item to bore in on is LAST...what does that mean?    It's the same question one asks about how long to toast bread. What are the inputs? Bread type? Wattage of the toaster? Distance from the elements? What is your preferred level of done?    So lets paint this with a broader brush. Oil is made up of the base and the additive package. The first is altered by heat and oxygen and later is sacrificial with a finite life subject to inputs toward that end. Resistance and supply.    It is the reason an OEM's OCI's are determined by 1.) the specifications of the recommended lubricant and 2.) risk management toward the bottom line. Those lubricants are also subject to cost effectiveness for the OEM.    There is a tendency for most people to believe that the OEM recommended oil rest on the top shelf and that anything other is lesser than. Truth is there are more oils on higher shelves than those on the lower shelf below the OEM's. They make that choice on COST TO THE OEM. Testing is incidental to the margin.    GM makes MONEY, the car/truck is a TOOL to leverage MONEY. Insert whatever car brand you like. Until you forking over a million plus COST not quality is the driver. Thus it is by DESIGN the recommended OCI's and oils fall well short of 'best practice protections'. Proof isn't hard to find. GM Ecotec I-4 2400 breather system and cold start PCM tuning has killed more motors and resulted in more litigation for those that used the 'recommended' practice than GM could bear. What was their response? SHORTEN THE OCI. TWICE.    I don't know how long to leave oil in an I don't know how the oil will respond to MY circumstances and because I don't and can't blanket statement or anecdotal evidence my way out of it.....I TEST and FIND the right OCI for the oil I CHOOSE. There is no shortcut but there is blind allegiance. I don't blindly trust anything.    People hear the word 'detergent' and believe that in the context of oil it means the same thing as laundry soap... Only in the most rudimentary way. It's the first additive to give up on you and they are putting less and less with each new API standard. Solvency can be used but it cost. Some unique undisclosed chemistries can be used. Valvoline R & P in example. OEM's haven't an interest in anything they see as limiting market participation. Whatever.
    • For some unexplained reason my father wanted a salvage yard. As we were getting the family business off the ground one brother ran the salvage yard. We gathered there when rained out working on pipelines in the eighties to pull parts. Perfectly good running vehicles would come to us simply because they wouldn’t pass emissions inspection. We were able to swap parts and sell some of them. I got a clean old nova with a bad engine. I pulled a perfectly good small block out a Camaro. A father and son project with a rebuilt engine. The son couldn’t get the engine running right. The problem was the spark plugs weren’t gapped. The 90s vehicles probably widened the gap of shade tree do it yourself engine repair. My do it yourself hot rod repair stopped at the 70s. After that my trusted mechanic kept them in running shape.
    • I have an old dental chair in my shop. Something I got for free and apparently it has more than scrap value? People collect them although mine isn't restored or anything. It's visually interesting (1930's Ritter) which is why I like it. And it IS decently comfortable if you kick back.   When a good buddy of mine saw it he said, let me guess, Atlas. It's a conversation piece? As in, you ask the questions, they do the talking?   Where do you hide the jar of teeth?   I would never.
