Here is my truck with 1.5" level kit with 285/55/20 Terra Grapplers and factory mudflaps.
Do you notice a mpg differeance going with the 285/55/20's? I'm torn between 305/55/20's or 275/60/20's
so what is better for the coil spacer up front... Polly or Steal ? I see some places offering both
I have seen aluminum as well for the strut spacer. My coil spacer is steel.
Sent from my Samsung Galaxy S4 using Tapatalk 4
Looks great!
A bit off topic:
I see everyone going with the 2" leveling kit. Is there a reason y'all are choosing this over the 2.5"? Ive been on the fence about which kit to order for a while now and I'm looking for some input to help me make a decision.
I have the 2" kit because I didn't want to go bigger tires and think it looks great without having to do blocks. However, I am now considering an extra inch in the back. We picked up a 12' pop up trailer and I have a feeling it may sit lower in the back with truck bed loaded with wood etc and trailer hooked up. Anyone have experience with towing and drop? I noticed about 2" drop in back
Don't get 2.5.... I heard it can mess with the electric steering in the new trucks. I would get a 1.5 inch or 2 inch max. I have the 2 inch kit, I almost wish I would have gotten on the 1.5 inch. My truck sits about 1.5 inch higher in the back. I have the stock 275 tires, and will keep it that way
Sent from my XT907 using Tapatalk 2
Don't get 2.5.... I heard it can mess with the electric steering in the new trucks. I would get a 1.5 inch or 2 inch max. I have the 2 inch kit, I almost wish I would have gotten on the 1.5 inch. My truck sits about 1.5 inch higher in the back. I have the stock 275 tires, and will keep it that way Sent from my XT907 using Tapatalk 2
Did you hear that it will mess with the electric steering from someone you know or was this a thread somewhere else? I guess what im asking is is this a reliable source? Links?
I plan to go with large tires when i do the leveling kit. I plan to run 305-55-20's on my stock wheels. I was told tht they would fit with a 2", but i like the idea of having another 1/2" in height just in case.
The 4x4 shop that installed mine.. I think the guy is pretty reliable source. He has been doing this for 25 years. I can't remember exactly the details... he just said after 2in, you could be asking for trouble. And he said it had something to do with electric steering and / or linkage to it. I didn't remember word for word because I knew from the start I only wanted 1.5 or 2in anyway.
Do you know this for a fact or did a friend of a friend say that.....2.5" front w/3" block 700 miles and no issues!!!
Edited by MR. DRAG SLEDDER
17mpg, that's basically what in getting with stock tires thanks!
I have the 2.5 kit, 1500 miles no problems at all.
Guys with the 2.5" front kits, can you post pics? Also what size tire are you running. Going to be leveling my Dads '14 this weekend with 2.5" front and swapping rear blocks to 3" and running 295/55/20's on stock 20's, but am considering 295/60/20 just think they will be too big and cause rubbing issues especially since he must keep the oem mudflaps. Thanks, all the trucks posted in this thread look great!
I just got the 2" rough country installed on my truck. It looks great, but I have noticed a little difference on the highway in terms V8 to V4 transition. It is definitely less aerodynamic with the front spacers and wants to kick back into V8 earlier than before.
    DM22
    DM22
  • Who's Online   6 Members, 1 Anonymous, 1,658 Guests (See full list)
    • Did have to make 1 modification because of the WeatherTech rear mud flaps and that was needing 3 longer screws than what came with the install package. 😄
    • Picked up the liners yesterday. Installed passenger side WITHOUT any modifications. All mounting holes lined up perfectly. Rain is interfering today with drivers side. Very Happy! Will add pics when finished
    • That is a fair point, and I agree that trying to log “everything in the truck” would be the wrong direction.   There are a lot of modules and a lot of traffic. If the product became a full-truck datalogger, the amount of data would get huge very quickly, and most owners would never use it.   I think the first useful version would need to be narrow: - powertrain-side event evidence - selected high-value parameters - communication / voltage / reset events - pre/post event window - short report first, raw log only as backup   One distinction I should make is between active OBD/PID polling and passive bus capture. If you are polling PIDs through OBD, then yes: the more parameters you request, the lower the effective sample rate becomes, and you are adding diagnostic traffic to a vehicle that is already busy running itself. With passive CAN capture, the recorder is not asking all the modules for data. It is listening to traffic that is already on the bus. So it does not consume vehicle bus bandwidth in the same way that a scan tool polling hundreds of PIDs would. But your point still applies in a different way.   Even if passive capture does not add bus traffic, the recorder still has limits: - processing rate - storage rate - timestamp accuracy - decoder workload - event filtering - report size - user attention span   So the answer cannot be “log everything and let the user figure it out.” The product would need to store enough raw evidence to be useful, but only decode, graph, and present the important parts around the event.   A practical report should probably show: - what triggered the capture - how much pre/post data was preserved - which selected parameters changed - how those values compared to baseline - whether the same pattern happened before - whether any voltage, reset, bus-off, lost-message, or communication fault occurred - selected graphs around the event - raw data only as supporting evidence   So I agree with you. More data is not automatically better. The real product is the reduction from raw data into a useful event report.
    • That makes sense, and I agree with most of that.   I think the product would need both: 1. a default powertrain template, so it is useful out of the box; 2. user-selected priority parameters, so the owner or shop can choose what they want to see first.   Different users are going to care about different things. One owner may care about oil pressure and voltage. Another may care about misfire trend, AFM/DFM behavior, or U-codes. A shop may want communication events and repeatability first. Your baseline point is probably the most important one. Raw data is not very useful unless the report can show what normal looked like for that vehicle under similar conditions.   The way I would think about it is: - start with a basic known-good baseline - learn normal behavior for that specific vehicle over time - allow the event to be overlaid against baseline - show whether the event was a one-time spike or a repeatable pattern - provide a simple severity level, but with clear limits on what that severity means   For example, early severity could be something like: - Info: event captured, no obvious abnormal pattern - Watch: value moved outside baseline, but not repeated - Warning: repeatable abnormal pattern under similar conditions - Critical: communication loss, voltage drop, bus-off, reset, or severe repeated event   I would not want the first version to say “replace this part.” That would be overclaiming unless there is repair-confirmed data behind it. It would be more honest to say “this pattern deserves inspection.”   On the OBD port question, I think OBD absolutely has a role. OBD is probably the right place for: - DTCs - freeze frame - VIN - calibration information - normal scan-tool parameters - Mode 6 / enhanced diagnostic data if available The reason I am still looking at an ECM-side recorder is that the failure may happen before anyone connects a scan tool. If the owner plugs in a scanner after the event, the pre-event evidence may already be gone unless the ECU happened to save it. So I do not see this as “OBD versus ECM-side.” I see it more like: - ECM-side recorder: always armed, rolling buffer, event evidence - OBD/DLC companion: DTCs, freeze frame, VIN, calibration, normal scan data - phone/cloud: status, notes, upload, report generation, notifications   I agree that phone connection and push notifications would be useful. I just would not want the phone or cloud connection to be required for capture. The recorder should save the event locally even if the phone is not connected. The phone should help with event marking, download, notes, upload, alerts, and report viewing.   For a default GM V8 event report, would this list make sense? - RPM - calculated load / MAP - throttle position - vehicle speed - gear / torque converter state if available - coolant temperature - oil pressure - oil temperature if available - battery voltage - commanded AFM/DFM state if available - actual AFM/DFM state if available - misfire counters / roughness by cylinder if available - fuel trims - relevant U-codes / communication events - bus-off / lost periodic message / module reset / voltage drop events Which of those would you remove, and what would you add?
