That's what I thought, just wanted to be sure because I'll be ordering a set soon and I cant decide which one I should get. I know the size will be 275/65/20 but still undecided Toyo Open Country AT or MT. I might go with the MT for the more aggressive look.
Also realize that there is Open Country AT and Open Country AT2. I have the AT on my truck. The AT is an older model and some places still carry them. The sidewall is less aggressive looking on the AT than the AT2. Just be aware.
I'll keep that in mind thanks.
Sent from my SAMSUNG-SGH-I337 using Tapatalk
20", 35 toyo mt
Looks good!
What lift are you running? Those are stock wheels right?
Installed a readylift leveling kit about 2 weeks ago. Went to re-check all bolts and noticed a couple things that I wanted to check with everyone here. 2014 Crew Cab LTZ Z71 4wd. Installed 2.25" Readylift up front and their +1 in the rear. Noticed that the "washer" looking pieces inboard of the bolts on the bottom of the strut seem to be pushing out at the top. Anyone else seeing this on a stock or leveled truck?
Also, there seems to be a contact point between the spindle and bottom control arm. Think its just a steering stop but wanted to double check that as well.
Spoke with a ready lift tech and he said steering stop seemed normal but the bottom strut issue might be a problem. One of the other techs he had look at the pictures said it was completely normal.
Any input is appreciated.
I have a rough country 2" level kit still new in box that I would like to sell. Bought it before reading about all the work involved and just really don't want to mess with it. I'm asking $50 shipped. PAYPAL would be an acceptable form of payment.
If interested just PM me.
Thanks
Okay, here's a question that might seem repetitive! Is anyone running 275/65/20 Toyo Open Country MTs on the original all terrain wheels with the RCX 2.5 level kit? I looked thoroughly before posting and couldn't find any pictures. I did see some running the same size tire but in the all terrain tire not the MT. I wonder if they will rub a lot more than the ATs due to the more aggressive tread. I am scheduled to get my tires installed tomorrow so i am hoping someone has some pictures and info on the setup. If not i might have to play it safe and go with the 33s.
My TGC kit included new nuts, bolts and washers. IDK if I'd feel comfortable with using the stock clamp nut with a spacer or even running stock clamp nut with no spacer for that matter. Seems like it could be an easy point of failure.
I would grab a set of grade 8 or 10 (can't remember which they were) nuts, bolts and washers and replace all the stock stuff just for piece of mind.
The hardware that came in my kit was from Fastenal
Edited by Full Lock
With a rough country 2" up front and 1" block in the back will goodyear duratrac 285/60r20 fit with no rubbing?
Picking up a 2014 Silverado 1500 CC SB 4x4 this week. It has the stock 20s and I'm putting 275/65s toyo mts on it. Would like it to have a slight rake. 2.25" will get me there? 2.5" would be completely level right?
I sit level 39" front 39" rear with readylift 2.25 but im on 285/45r22
different brands vary in height.
Edited by scoobyd3w
Scooby, did your front end come up exactly 2.25"? Just trying to find out if the actual number is the actual lift. If so I guess a 2" would give me the slight rake I'm looking for.
Will both of these work on 2014 1500 all terrain with a 2" RC leveling kit?
Goodyear duratrac
285/60r20
305/55r20
Anyone currenty running one of these setups?
285/60R20's will work but the 305's will rub with just a leveling kit.
Before the level the mechanic measured from the bottom of the fender well to the ground and the front measured 37" and the rear was 39"
After the readylift 2.25 Part# 66-3085 the front fender measures an almost exact 39" depending how eye level you look :freak:
After install did an alignment and the truck feels great without sacrificing any ride quality!! hope this helps..
If you still want the rake look you might try the 2.25 level with a 1" block in the rear...
Edited by scoobyd3w
Well the readylift 2.25 front level kit is installed, and a 3" block on the back...Like the rake plus I tow a boat, sled and quad so needed it for sag. Anywho looking at beefing up the tires a little. Looking at nitto terra grapplers or cooper zeon ltz. Looking at 305 50 20...Thinking they should work by size calculator but any experience would help if you would like to chime in!
Would like to see some pics please. I have 2.5" RC lift and thinking about installing 3" block to gain some rake, did you use shock extensions?
    Smitty462
    Smitty462
  • Who's Online   4 Members, 0 Anonymous, 534 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
