Picked up a new 2015 Z71 GMC crew cab 4x4 today. Front measures 36 1/2, rear measures 39 1/2. At what point on a leveling kit would new UCAs and/or a diff drop be required? Looking at the Bilstein 5100s set at next to highest setting or a 2" spacer.
Anything above 2.5" I believe. You don't want to go any higher than that without replacing your UCA's.
To those that have been leveled for a while, is your ride quality notably affected? Been considering leveling my 2014 LTZ Z71.
I've had mine level with the 2.5" RC since last November and can say I see no difference from when it was still at the stock height.
Thanks for the input. Did you do the rear too? If so how high in the back? z71 chevy's truck above looks great with just the front done.
Also, did the 2.5" RC kit affect the front enough to require an alignment?
Any levelling kit is going to require an alignment. Anytime you do anything to the front suspension of a truck you need to do an alignment…
Edited by Daly
I put the rear block that came with the 2.5" Level/Lift kit. The shop that installed the lift did a wheel alignment as well.
I went with the Bilstein 5100 adjustable shocks and the ride is about the same. It might be slightly stiffer but, that has more to do with running higher pressure in my tires than the shocks not performing.
RC 2.5" on my 2015 Sierra SLT, had to drive it down a curb to see if the steps would scrape (they didn't)
Cool. Just got my rough country level yesterday. Gonna try to put it on this weekend.
Sent from my SAMSUNG-SM-N910A using Tapatalk
Just got done putting on my 1.25' Body lift & and 2' Leveling kit from RC this weekend. That wax dipped frame on the truck sucks a$$! I've been yelled at several times this weekend, for getting it all over the house by my wife?, anyways I think 33's are next on my to do list.
Stock height
Body lift & leveling kit
Edited by DubDeuce84
Just got done putting on my 1.25' Body lift & and 2' Leveling kit from RC this weekend. That wax dipped frame on the truck sucks a$$! I've been yelled at several times this weekend, for getting it all over the house by my wife, anyways I think 33's are next on my to do list.
Stock height
Body lift @ leveling kit
I wish I could put better quality pictures on here, i'm probably doing something wrong.
How much of a pain was it to put the body lift on? I am currently running the Pro Comp 2.25" Leveling Kit, 2" blocks in the rear, and 33X12.50 on the Denali wheels.
My thoughts are if I put a body lift on I can run 35s.
Being that it it was my first body lift I've ever done, and I was the only one that did it, it took every bit of 6 to 7 hours, but if you can get someone to help you it will make life a lot easier. Also that wax coating on the frame gets everywhere, but I'm happy with it.
Also got a look at the price difference between the suspension lift in a body lift, that's the reason why I did it, and it doesn't change the ride quality. Also the gap is so minimal you can hardly notice it unless you are looking for it. To me it looks like a 2500
    White.6.2
    White.6.2
  • Who's Online   5 Members, 0 Anonymous, 559 Guests (See full list)
    • I have never seen GM instructions for the other trucks as per the HD with the 6 speed or the half tons but had got the impression that the HD trucks with the 6 speed were not having the same problem that the 10 speed and pan presented. Also video that I have seen of the HD 10 speed with the gas engine starting in 2024 model year showed that it was a real struggle to even make it work when pulling down hard on the exhaust after undoing the exhaust hanger bracket on the side of the transmission as after all there is little room for the pipe to even go down behind the Y joint as it soon would hit a frame cross member. Also that they had tried just like I did with the gasket off and no way was that pan coming out any way they tried to manipulate the pan. From that as well as the local transmission shop talking about the pain in the rear issue, I was not expecting my pan to come out because GM shows it was not even intended to come out without dealing with the exhaust piping.    It would be nice to claim, here's what you do and its easy to remove the pan guaranteed on any HD truck with the gas 10 speed but dollars to donuts the next guy trying what I did would not have the same luck as the exhaust was just manufactured slightly different and be pissed off at my claim that the pan comes out with no issue. Its more of a try and see if your particular truck might work like mine did .... or not !.
    • Sorry I didn't see this until now, but it works on both the 6 speed and 10 speeds, as well as all the half tons too.
    • Hello, I have a 2018 GMC Sierra 1500 that I recently changed both motor mounts on due to the driver's side being blown out. After replacement I seem to have a steady vibration that I can feel in the pedals and the back of the seat. At this point I'm convinced that the aftermarket "Anchor" branded mounts I used are not performing as well as OE, the only real reason I ended up using the mounts in question was because my local dealers were out a few months to get a Driver's side mount. I've tried "Neutralizing" the mounts according to the motor mount TSB published for these truck to no avail. My trans mount is also in great shape and seems to be absorbing vibrations swimmingly. As far as I can tell there is no issues idling, my idle RPM is steady and I've recently put GM plugs and wires on, however, I have not cleaned the throttle body or intake valves. Any one else have a similar experience with aftermarket mounts? Patience certainly is a virtue that I wish I exercised here. Thank you!
    • I still saw people out for runs, on their bikes/motorcylces, jeeps with the doors off driving around here the past 2 days. I guess we are just used to it here haha.   Tasted like a bonfire the last 2 days.
    • The TCM has to be flashed before it can drive.   If you installed it the way it is, it has the OS (operating system/program) from the 2010 truck you got it from. That will not match with the VIN/OS pair that your 2013 truck has.   You can do the full install. Then tow it to a dealership and they can flash the trucks PCM/TCM with the latest program for your VIN.
