I talked to the installer today. He said with the Zone body lift he had to cut the frame to raise the rear bumper. Is that true ? That's why he didn't do it.
I didn't have to cut anything on the rear except maybe an 1"x.25" notch over the bar for the spare tire so it could lift high enough to fit in bumper still Edited by z71 chevy
Thanks that's what the instructions said but I couldn't call him out on it. till I was sure thanks again.
Edited by JimmyJ_123
I guess my thought was that since there is a 3.5" lift from RC that only replaces the upper control arms (just a better ball joint is my guess) and everything else is the same with spacers and a diff drop...
The Arms in the RC 3.5" kit help with the ball joint angles and droop stop issue but that is it. Tie rods and lcas will still be maxed out. If you look on the forums there is a long track record of that kit causing premature front end wear.
Here are some better pics, 2" RC w/ 33x12.50r18 tires
Edited by nando87
Just got home from getting the truck leveled.
2" Rough Country Level. Stock wheels and 275/55/20 tires.
Now the hunt for 275/60/20 starts, or maybe 305/55/20.
Sent from Tapatalk App - Samsung S6
Looks good!
Looks good!
Thank you.
Now, besides the obvious need for larger tires, I am torn on what to do to push the wheels out some.
I can either run a 1/4" spacer (which will probably net in not much for looks), or run a 1.5" spacer/adaptor (which will probably net in sandblasting the side of the truck, as that would put the wheels ideallly the same as a 20x9 -12 would).
Last option, get new wheels/tires in a 20x9 +0 offset (or something in that range).
Offsetting will make it look even badder no matter which option you choose.
Did you do an alignment after the level?
Sitting at the local alignment shop right now.
Has anybody done the 2.5" RC level kit but instead of using the rear blocks, taken the factory block out and putting in an add-a-leaf? I have a 15 crew cab z71
Here are the wheels, more pics below of the level.
Any issues with 275/60 R20 vs 275/55 R20 with chevy dealers? Any threats of voiding warranty, etc.?
I have a gmc with 285/60/20 tires with 20x9 aftermarket rims with a level kit on it I haven't had any problems at the dealership I take it too for any warranty work done. But the dealership I take it too sells alot of lifted trucks so I don't know if that makes a difference or not
I am going to do the 2.5" RC lift soon (1.25 RC body lift later this year). I would rather have the dealership I bought the truck from do my alignment. Is about 20 miles too far or not an issue.
Thanks
    whenindoubtuseahammer
  • Who's Online   2 Members, 0 Anonymous, 381 Guests (See full list)
    • Its no wonder you've gravitated to the oil types and brands you have in later years after trying certain brands and one being a specialty oil or at least very hard to come by up here and the other would have been a commonly found oil of the era and the vastly different outcomes as a result to using the vehicles in question the same distance for an OCI . It shows what marketing hype can do without actually having the product to back up the claims and that is no different now with the insane claims that are written on the side of a bottle of oil from some of the off the shelf oils.    What has surprised me and I was already finding this out before I bought my truck with the GDI engine, that this newer fancy technology that seemingly would suggest better fuel economy/emissions with this high pressure spray of fuel is not in reality kind at all to the engine or at least the oils life. Yet they insist on claiming long OCI with this technology just like they did with the port or similar type fuel injection systems when in reality its a step back in oil life to have a GDI system.    I think the mistake your making Grumpy is that your not sending your samples to Blackstone and getting the feel good glowing report that you can run it another 1000 or more miles and then send another sample where they say run it yet another 1000 miles and on and on it goes until your sending in something that looks a lot like road tar and then they may suggest you change your oil within the next 1000 miles 😆
    • I am guessing that engines of that design back then had a better ability to be abused and survive longer than a new design engine with the long timing chain and the overhead cams and phasers etc. But I would never guess that an engine could go that far and not fail spectacularly or at least die a slow death.
    • In the 80's 90's I'd run Honda's 7,500 miles between changes using Red Line HP 5W20 and do it for hundreds of thousands of miles with issues. Back in the day it was an SAE 20 with the HTHS of a SAE 30 and SN add load. It was also very polar. Oxidation VOA was over 120. Besides those motors were SPFI and lean burn tech. I could have likely run it longer but never did.    We had a Toyota bought new I ran on Pennzoil's latest and greatest synthetic of the day with "Penthane". A made up word for a very low dose of PAO. Tried 7,500 mile OCI's in that Group III/VI chemistry and the rings tapped out at 90K. Rocker box wasn't as bad as the one Punch put up but it wasn't good either. Also a SPFI motor.    I'm around 3,750 across the board on these GDI monsters and the oil it tapped out by then usually on TBN/TAN crossover and color. Red Line HP Euro.    The AMSOIL SS brochures tell you to follow the OEM values for the service class but that it can be run up to 25K if monitored. I can't imagine what motor could go that distance and not tap out. I've never owned one.    Yes, I know. Lot's of people do. I'm just not going to be one of them.
    • I knew a guy in the early 80's that bought a new Monte Carlo and ran it a 100,000 miles without ever changing the filter or the oil. Just kept adding. It looked like that inside.
    • Good evening. I was lucky enough to get passed down to me a 2007 GMC LBZ that was my great uncle's. While the underside and rockers are more or less gone I feel like with time I can restore it to working order since it only has 110,000 miles and he put nearly every option he could get without getting the new body style since he did not trust DEF. So far I have done everything I can think of but when I put the key into the ignition nothing happens. I put 2 brand new batteries in it. Cleaned the terminals. Check all the fuses and relays and they all pass with my multimeter. I know I'm missing something that I just cant think of. The only odd thing is the OBD2 port works which makes me think its not the mega fuse. Any advice would be greatly appreciated.
