It looks like it sits higher in the front a little or is it just me?
Sent from my SAMSUNG-SM-N910A using Tapatalk
It is a full inch higher in the back 39.5 in the front 40.625 on the back. I could have take a better shot. I think there was a slight incline on the second shot.
Edited by rscjr1969
Oh ok. Thank you sir. Beautiful truck btw
2.5 leveling kit 1.5 body lift. New tires 35/12.50r20 .. zip tide fender flares back ..other then that no trimming .Tires r atturo trail blade xt
What is the offset of the wheels? I have the same set up and wondered if 35s would fit. The wheels Im looking at have a +0 offset.
Has anyone leveled a truck with say a RC 2.5" kit and then upgraded the coilovers to a Fox or King brand?
I understand that Fox and King are adjustable but I'm concerned that if I lift them too much, the ride will be too stiff. If I run a spacer and the Fox's on the factory setting, then I may get the best of both worlds?
Make sense or am I completely wrong?
I think @spurshot can chime in on this. I think he upgraded to kings
Did the RC 2.5 today (Front only) Planning on doing the back just ran out of time today. Stock SRA tires for now
That looks good. Can't wait to do mine
I'll second that, looks great.
Surebuttercringe first off sorry your a Ohio state fan lol .. Arkansas boy just giving you a little crap .. there +12 but tires only measure 34.25 and about 12 wide.. but do still clear body mount by 3/4 of an inch ..
so i just bought a 2014 silverado and got a tuff country leveling lit for it. i went to install the kit and ram into a little trouble, i had it pretty much installed on the passanger side and noticed tha my upper control arm was contacting what looks to me to be some sort of droop limiter. i put everything back together in the stock configuration. im wondering if once i nstall the kit completly if this will cause any issues with suspension travel.
Any reason why the torsion key leveling kit is not popular? I am referring to a replacement torsion key (ReadyLift) vice cranking on the existing bolt.
Edited by 15GMCSierra
The new trucks don't have torsion bars they use strut spacers to level
Thanks. I saw them on the ReadyLift website, but did not recognize that it was for 1999-2007 year models.
I would go with a ranch quick lift strut system if its the same as the older models. It did the job very well on my truck. I hope they come out with one for the z71 model.
The "Z71 model" is no different than any other 4x4 Silverado/Sierra and the Quick Lift struts work and lift 2". Not sure why Rancho claims it won't work with Z71 suspension, the only difference is shock stiffness when it comes to the OEM suspension packages.
2015 GMC Sierra SLT CC max tow
RC 2.5" leveling kit, I did not install the upper strut spacers because I wanted the front to still be slightly lower than the rear
BFG 275/60-20's. Wish I had gone with 275/65's!!
Picked up a new 2015 Z71 GMC crew cab 4x4 today. Front measures 36 1/2, rear measures 39 1/2. At what point on a leveling kit would new UCAs and/or a diff drop be required? Looking at the Bilstein 5100s set at next to highest setting or a 2" spacer.
    whenindoubtuseahammer
  • Who's Online   1 Member, 0 Anonymous, 295 Guests (See full list)
    • are there any codes? with lots of rust, perhaps disconnect/clean both sides of the connection/examine cable ends (the wires) for corrosion going into the sheath & replace if necessary/reconnect ALL the power AND ground cables between the battery, engine, frame, cab, fuse box and starter charm.li (website) has a no-start diagnostic procedure you can work through to get it working.
    • Its no wonder you've gravitated to the oil types and brands you have in later years after trying certain brands and one being a specialty oil or at least very hard to come by up here and the other would have been a commonly found oil of the era and the vastly different outcomes as a result to using the vehicles in question the same distance for an OCI . It shows what marketing hype can do without actually having the product to back up the claims and that is no different now with the insane claims that are written on the side of a bottle of oil from some of the off the shelf oils.    What has surprised me and I was already finding this out before I bought my truck with the GDI engine, that this newer fancy technology that seemingly would suggest better fuel economy/emissions with this high pressure spray of fuel is not in reality kind at all to the engine or at least the oils life. Yet they insist on claiming long OCI with this technology just like they did with the port or similar type fuel injection systems when in reality its a step back in oil life to have a GDI system.    I think the mistake your making Grumpy is that your not sending your samples to Blackstone and getting the feel good glowing report that you can run it another 1000 or more miles and then send another sample where they say run it yet another 1000 miles and on and on it goes until your sending in something that looks a lot like road tar and then they may suggest you change your oil within the next 1000 miles 😆
    • I am guessing that engines of that design back then had a better ability to be abused and survive longer than a new design engine with the long timing chain and the overhead cams and phasers etc. But I would never guess that an engine could go that far and not fail spectacularly or at least die a slow death.
    • In the 80's 90's I'd run Honda's 7,500 miles between changes using Red Line HP 5W20 and do it for hundreds of thousands of miles with issues. Back in the day it was an SAE 20 with the HTHS of a SAE 30 and SN add load. It was also very polar. Oxidation VOA was over 120. Besides those motors were SPFI and lean burn tech. I could have likely run it longer but never did.    We had a Toyota bought new I ran on Pennzoil's latest and greatest synthetic of the day with "Penthane". A made up word for a very low dose of PAO. Tried 7,500 mile OCI's in that Group III/VI chemistry and the rings tapped out at 90K. Rocker box wasn't as bad as the one Punch put up but it wasn't good either. Also a SPFI motor.    I'm around 3,750 across the board on these GDI monsters and the oil it tapped out by then usually on TBN/TAN crossover and color. Red Line HP Euro.    The AMSOIL SS brochures tell you to follow the OEM values for the service class but that it can be run up to 25K if monitored. I can't imagine what motor could go that distance and not tap out. I've never owned one.    Yes, I know. Lot's of people do. I'm just not going to be one of them.
    • I knew a guy in the early 80's that bought a new Monte Carlo and ran it a 100,000 miles without ever changing the filter or the oil. Just kept adding. It looked like that inside.
