54 minutes ago, jgraves13 said:
285/70 or 285/75?
295/70/18 rims have a 0 offset
Edited by CradleyBooper
19 minutes ago, jgraves13 said:
Any rubbing?
Yeah in the back of the fender. I need to do a NorCal mod on it but I’ve been lazy about it.
Finally done! Went with 20x9 XD heists and 285/55 nitto ridge grapplers, it looks fantastic and also rides fantastic! I’ll get better pics later
f1a9dc17594df791f9febdf66dfc0d4b.jpgb67330b673970bca3ec5d8430488abd4.jpgbe3c72d292370adc513786a99980a576.jpg
Nice... I get my level and wheel/tire combo installed next Friday.... Can't wait!
Thanks! It makes such a big difference, been waiting 2 years since I first bought it to do it and the truck is just so much more aggressive and good looking now, you’ll love it
Definitely the right choice in wheels!
Thanks! I’m definitely glad I went with these, they look so good in person. It was no contest here on the forum the few votes I got were these!
I have a 2015 1500 crew and am thinking about 2.5 level in front with 22x9 and 33x12.5? Will this sit level?  Anyone have any concerns with this fitment or look? If you have this set up please post pics...need help deciding
Very nice! Great choice on the wheels and tires!
I finally got my leveling kit installed and 275/65/20 firestone destination mt2. I love the new look.
  • Like 4
Thinking of what to do. Ive seen some amazing setups but i do a lot of Expressway/city driving. I either want a great Leveling kit or nothing more than a 4inch lift. I want to keep the stock wheels but give the truck a more aggressive look for a daily driver. Its ChiTown area so winters can get crazy. Im shooting for the BFGsALL Terrain . The stock tires are 275/55/20.
Edited by CASHss02
Nice truck I have the exact same one lol
Twining.... Thank you Charlie Sheen
    250.6k
    President Roberto
    President Roberto
  • Who's Online   1 Member, 0 Anonymous, 285 Guests (See full list)
    • I don't wanna do major surgery/upgrades, behind-the-dash work, add amps, change radio etc. on my '26 std cab WT. On the WT, it has the base 7" IOR infotainment setup, and only two speakers (doors). Since I listen to classical, looked around for speakers that do well and dug thru reviews. Two-way speakers were found to be better than 3-way. So I've ordered a pair of  Infinity Reference REF-9632IX 2 way speakers.  [These may  or may not have been discontinued / succeeded by the 3-way ...9633 ones.]    These speakers are lauded for 3 ohm and 94db sensitivity spec so they'll work well for ordinary base car radios without amps and offer better performance (quality,  strength) than  default base paper-cone speakers. They'll be installed in a few days and I'll let y'all know what I think. Bill W San Jose
    • Thanks!   Changed out the rear shocks today to Bilstein 5100s.  So far feel much better. The stock Rancho were wore out.  Lots of heavy hauling (2 moves, home renovations, etc).  Next up is new BFG tires Monday.  Cant wait the current tires have little to no wet traction and are super loud (hum)
    • Ok, I got the all the codes. What do you all think would be a place to start?
    • How about I just point to the factory pans stand pipe little drain plug and claim its a pan with a real drain plug !. I just couldn't swallow the fact that a Dorman pan which at this point is probably the only pan out there that fits the gas version truck cost that much up here in Canada so I decided initially anyway to skip it and see what I thought of pulling the pan method and down the road if I felt inclined enough then I would either install a drain plug kit in the factory pan if there is enough room for it, or have a bung welded onto it, or put an aftermarket pan on. The thing is if the pan is not pulled then the magnets in the pan can't be inspected and cleaned or if wanting to change out the filter. However of course it certainly would make the job easier to be able to drop the oil first before having to handle the pan if dropping the pan that go around was the goal.    I knew a guy locally that was doing custom field spraying years ago with a pickup pulling a ground driven sprayer, I believe it was a GM pickup with an automatic trans. He had a drain plug in his pan and would drop the oil out of it once a week and top it back up through the dipstick tube to keep refreshing a portion of the oil often and that made the transmission last far longer than had he done nothing. Soft fields pulling 500 gallons of water at the start of each mixed up sprayer tank batch and in low range sucking along. I imagine he got some tips from other custom sprayer outfits doing the same thing at the time and learning from their blown up tranny mistakes. Transmissions then had no lock up converter so would cook the crap out of the fluid slipping that much and it would not have been synthetic fluid either.
    • 3.39 Kroger’s in Montgomery Texas.
