On 3/8/2018 at 7:56 PM, 6.2_GMC_DEN said:
Do you have any vibration like in the floor when in 4 wheel auto
I can’t be the only one has the vibration issue with a leveling kit out there! Like I said my ‘17 denali was perfect with a rc 2” leveling kit. My 18 denali shakes under a load. ESP in 4 wheel drive. Had rc 2.5 and currently has readylift 1.5 with factory block in back. Both have shake issues. Really regretting my good buy on the 18 now ??  I guess if there is anyone else that had this issue, I’m curious what was done if anything to fix issue. Would really hate to go back to stock
Why did you go from a 17 to a 18? So without the level theres no shake?
Honesty the dealer called me and gave me an awesome deal. I really like this body style so I thought why not have the newest in this style I could get. Now I really wish I wouldn’t have. Yes without the level everything is fine.
2.5 rough country, seems like I didn’t get a full 2 inches of lift. Front I remember was about 36 1/2 and after kit I’m at 38 1/2. I had a shit ton of rake the back was at 39 1/2 and now it sits just under 40 1/2. Wheels and tires this upcoming Saturday throwing on 285/55r20 ridge grapplers on 20x10 xd 820 grenades
After looking around for weeks I went with 2.5” motofab leveling kit. I was lucky enough to have a 2014 GMC Sierra Denali before magneride or else that would have definitely cut down on my options. The place I got my wheels and tires had this thing installed in about an hour and 15 minutes. I love the simplicity of just a spacer on top. And so far the ride is same as stock.
Why would it cut down on your options?
I have the 2017 with the suspension maxx 2.5. all you have to do is have the dealer "re-zero" the magnaride in the computer.
i just bought a rc 2.5 in lift and plaining to instal only the 2 in front until i get bigger tire... on the 2.5in lift instruction they does say to unplug the electric power stearing but on the 2in lift instruction yes... does i need too or not????
Edited by math_10silverado
I didn’t do it because the clips were very fragile and where they plug into the electric power steering is a fragile area I could tell I was going to break if I kept trying to unplug them. I got one off but the other two plugs were not going off without breaking. I unplugged the battery and had no issues. You just need to make sure you support your lower control arm and knuckle after you break loose the upper ball joint and unbolt the ABS line otherwise it will snap. I couldn’t believe it wasn’t in the instructions to do that.
Just keep an eye on all brake lines and abs lines and you will be fine, I installed the 2.5 inch RC yesterday took about 3 1/2 hours for the front and rear.
im not removing the ball join i already instaled the rc 2in on my old 2007 and didn remove them ill try again if its still work only by removing the sway bar link
You have to unless you only want to do the bottom 2 inch, in that case why get the 2.5 kit.?
    contrabombarde
    contrabombarde
  • Who's Online   4 Members, 0 Anonymous, 1,407 Guests (See full list)
    • Some clarification may help with some of these issues.   - Rev Industries is/was the division of BAK (now Realtruck) that makes covers under the OEM names.  So if you see one with a Ford logo on it, or if you are buying the GM Accessories cover, you are essentially buying a BAK G2 cover with different branding.   - Rev Industries now markets under RealTruck "Advantage."   - As of May 1, 2025, the Advantage covers now have a 5 year warranty.  Anything before that was a 36/36K warranty.   - Parts for the covers are available from Realtruck or BAK.  The email address to reach them is [email protected] or you can call them at 818-365-9000   - If the entire cover has to be replaced, you have to go through your local GM dealer.  Service dept opens an RO, notes the damage and submits it as a warranty claim.  Keep your paperwork handy so they can confirm when you purchased it and it's within the warranty timeframe.  Once the warranty claim is approved, Parts orders the replacement cover.  When it arrives at the dealership, service will remove and install the new one for free as labor is included under warranty.   - The Advantage covers are not the latest and greatest Gen 3 covers.  They still use the old school clamps, elevator bolts, etc...If you want the newer technology, consider buying your cover in the aftermarket world.  That way, if you have an issue you can deal directly with the manufacturer.   - Finally, RealTruck has a program with many of their authorized dealers that doubles the warranty to 10 years if the authorized dealer does the install.     Hope this helps.
    • Welcome to the group!  My '22 just crossed 150K miles.  Runs perfectly.  Oil pump belt will be done in the next 30 days or so and onward hopefully for another 150K.  Love the truck.
    • Still looks like a rivet to me in the pics, I don't see a nut and none of the pics show the head of the screw. But if you says so.....
