That looks awesome! Going to do the same setup but with a 2" level until I can afford coilovers, and bronze NV with nitto g2s. Do you have any pics from the side? Truck looks great
18 minutes ago, Slatemetal15 said:
This is the only pic I have at the moment. 25fdecb52844c9dbab60a15e7da5c911.jpg
Can you get pictures of you bj angles and tie rod angle? Also what is the measurement in front center of hub to top of wherl well
Yes I will get pictures tomorrow, sorry it’s already dark outside. I did go out and measure center hub to fender though.
Before-21.25”
After-24.00”
On 4/29/2018 at 4:52 PM, MHardiman90 said:
Thanks brother! Motofab 2.5" level, rear is stock. BORA 1.25" wheel spacers. Toyo R/Ts 33x12.5.
Man, your trucks looks awesome! Perfect setup.
How much of a power/mpg hit did you take? Any rubbing?
So...I see people post (here and other places) shots of their trucks with 2", 2.25", or 2.5" and each will claim it sits perfectly level...sometimes I see a post of one with a 2" and I think it looks great then I'll scroll down and see one with 2.5" and think it looks great.  I do not want my '15 Silverado Crew z71 to look like the front is higher than the rear.  A buddy of mine said a 2.5" Motofab had his sitting perfectly level (by looks and measurement) but then I see Ron505's post of his 2" BDS and it almost looks like the front is slightly higher. lol
All that to say...I'm not going to be disappointed with a 2.5" Motofab on the front, am I?  I.e. it'll sit level?  Stock wheels/tires for now...will go slightly bigger on tires when I replace 'em down the road.
MHardiman90's looks great to me (looks level, etc.) but I guess I'm just on the fence and wanting to make sure I'm not going to show up when they finish installing it and regret something.
I have the 3/2 MotoFab kit on my 15 LT. I took measurements from level ground to outer fender lip. These pics are before I went up to 285/70/17. As you can see by the measurements I still have roughly 1” rake. I still need to get measurements since I got the bigger tires.
Before 3/2 level
RF 35 3/8
LF 35 3/8
LR 38 3/8
RR 38 3/8
After 3/2 level
RF 39 1/8
LF 38 3/8
LR 40
RR 40 1/8
Delivered via my cellular device using a mobile chat forum thingy.
I wish I had the factory 17's instead of 18's.
You went up to a 32.6" tire which is probably all you'll need to give it that balanced look.  Pics with the 285's would be great.
I’m actually looking for the black Police Tahoe wheels to get rid of my shiny ones. It looks more raked because it’s on my sloped driveway. a612550882444552f54b3ae905e73511.jpg
That right there is the look I'm going for.  Go up in tire size just enough to look right and to keep the mpgs close to stock.  Ive got stamped steel control arms so Ima go with a 3.5" lift but with new knuckles.
3 minutes ago, Slatemetal15 said:
Everything looks perfect
https://tiresize.com/comparison/
285/55R20 are smaller than 285/65R18 (by 1/3 inch tall)
check this out...that size is really close to 285/65R18...i think it would be fine...but as far as Duratracs...many people love them, I am not a fan...when I got my truck, I swapped them out for KO2s within a month...
I have 20’s, so I won’t be getting an 18” sized tire. Any one have input on 275/60/20 and the ‘look’ factor of them? Not a huge change from stock but enough from a side
Profile that I think it fills the wheel wells better than a 55 sized tire.
Thanks bud! I lost about 2 miles per gallon. I'm averaging about 16-17 now but on highway I get up to 21mpg. Very happy! Only rubbing fender liners on full lock and a little more in reverse. No big deal though, either go to trim or pin back.
Edited by MHardiman90
    B07
    B07
  • Who's Online   3 Members, 0 Anonymous, 795 Guests (See full list)
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
