On 5/1/2018 at 12:54 PM, 17SLE said:
Here is my truck after the dealer installed a 2.25” level. Put some 285/70/17 Mickey Thompson P3’s on it.
Can you get a picture of you upper and lower NJ angle and also your tie rod angle
I just installed a 2" BDS Level kit, because I got it here in the classifieds for cheap.  I may add another .5" at some point.  Stock wheels and tires for now, with 2" spacers on the wheels.  I'll be adding a Zone Add-A-Leaf (and put my cap back on), and 305/65-18's.
Edited by Ron505
So I need peoples input. I have found a temp setup so suit my needs for a few months.  I'd like opinion
2.5" motofab level.  Wheel is 20x9 +10 offset on a 33x12.5?
What year truck do you have? I have a 17 All Terrain with the same set up but with et37 and 1.25" spacers and still rub at full lock on liners. My offset is about +5 with spacers. You'll rub slightly more than me if you have a 16, 17, or 18.
16 regular cab
Just now, Nasty said:
16 regular cab
You should rub liners but should also clear the upper control arms fine. Liners are easy, either trim them or pin them back. Good luck!
And I was wrong. It's a 295 55 20
Has anyone done the Readylift 2.25" kit with UCAs on a 17 Silverado and run 275/65r20s?  I searched and couldn't find that exact setup.  Unfortunately, I have the stamped steel control arms and everything I read says they are trash with a level so I figure I should go with something that swaps them out.
Alright so ... are 275/60/20 going to ‘look’ too narrow when I level? [emoji51]. Pretty set on this size as I feel it’s a good price and modification compromise.
Leaning towards the Duratracs for daily driving (city:highway)
I would go 285/55r20
9 hours ago, Aaron1085 said:
Alright so ... are 275/60/20 going to ‘look’ too narrow when I level? emoji51.png. Pretty set on this size as I feel it’s a good price and modification compromise.
https://tiresize.com/comparison/
285/55R20 are smaller than 285/65R18 (by 1/3 inch tall)
check this out...that size is really close to 285/65R18...i think it would be fine...but as far as Duratracs...many people love them, I am not a fan...when I got my truck, I swapped them out for KO2s within a month...
So...I see people post (here and other places) shots of their trucks with 2", 2.25", or 2.5" and each will claim it sits perfectly level...sometimes I see a post of one with a 2" and I think it looks great then I'll scroll down and see one with 2.5" and think it looks great.  I do not want my '15 Silverado Crew z71 to look like the front is higher than the rear.  A buddy of mine said a 2.5" Motofab had his sitting perfectly level (by looks and measurement) but then I see Ron505's post of his 2" BDS and it almost looks like the front is slightly higher. lol
All that to say...I'm not going to be disappointed with a 2.5" Motofab on the front, am I?  I.e. it'll sit level?  Stock wheels/tires for now...will go slightly bigger on tires when I replace 'em down the road.
MHardiman90's looks great to me (looks level, etc.) but I guess I'm just on the fence and wanting to make sure I'm not going to show up when they finish installing it and regret something.
That's because in reality .5" from 20 feet away isn't noticable. I think you'll be fine with whatever you get!
Yeah, I guess you have a point!  I'm probably overthinking it lol thanks.
Anyone fit 295/70/17 on a 2" level? Not many pics online and trying to see how they look compared to 285/70/17
I just got done with my truck. 295/70r17 Toyo RT’s on method NV 17x8.5 0 offset with no rubbing. No trimming, cutting, or even zip ties on the liner. 2.5” lift in the front with king coilovers. New camburg UCA’s also 5d79f27b1905767fd09396e508558b16.jpg3eb2a6371dd608075375b90d3da03cee.jpgc0bdf6b40a421c7e421ea95a081dc374.jpgc0bdf6b40a421c7e421ea95a081dc374.jpg
    DaleB
    DaleB
  • Who's Online   1 Member, 0 Anonymous, 1,266 Guests (See full list)
    • My truck is a ¾ ton but my placard also says 80 for the rear tires, I think I might have the upgraded suspension to the 3500 series maybe.   I put my air down to 60 and the light was still on, and there was no way I was putting over 60 psi in the rear empty and not towing because I knew the actual number Toyo gave me and I didn't wanna ruin the center of my tires!   And you actually can change it in the settings from metric or is and it will show kph or mph then when you go into your tire settings it will be either psi or kpa, but it would be nice to just change it directly on the tire psi page
    • Common Sense Assembly   Your driveline is forgiving of the occasional mistake. It will even often forgive the random serious blunder. But it will not forgive a continuous bad habit.      What? Not everything needs to be a five thousand word essay.
    • We drove about 15 minute east today to visit a friend and saw a steep increase in price in the same county. About 50 cents a gallon steepper.
    • Sure about that? A degree wheel and a dial indicator would lower your degree of assurance in that statement. 😉    It why we have offset keys and dialable timing sprockets. Just say'n.... I've built a few and have never seen one "On the money".
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
