Just put on last weekend a Rough country 2” front level and some 20x9 0 275/55/20 e8b4473d7db557f33eb4c0b1256c16c0.heic3fcb23d27d7221ebb528d1500ad21db0.heic
Rough country 2.5 front only, Readylift UCA’s. Gotta measure on level ground but I think im only about 3/8” of rake now, may throw in the rear block
Edited by Arkangel
Your CV boots aren't contacting your lower control arm?
Im not sure, should I be concerned? Maybe the angle of the pic or maybe because its at a slope up the driveway? Ill recheck it tomorrow when its light out again
Edited by Arkangel
Yes they are, they’re after market UCA’s specifically designed for that lift.
Looks great, your UCA’s look great too compared to stock.
Another member mentioned that my CV boots appear to be contacting the LCA, should I be concerned?
Btw, get rid of those crappy Chinese rancho knock offs and put on some Bilstein 5100’s unless you off-road a lot instead Fox coil over Shocks.
You do not want that CV rubber boot to touch anything cause it spins while in use. Better get that checked out immediately!!
Damn! I just had this put on this afternoon! Shouldnt the shop have seen that?? 2.5” too high maybe? Just went out and took another couple shots with the flash its damn close
Edited by Arkangel
Are those pics with the truck jacked up in the air or sitting on the tires??
Parked the driveway at an incline, not flat
Edited by Arkangel
Sorry buddy, those rubber booties shouldn’t be touching anything but air. Looks like a spacer may be left out somewhere. What’s your Leveling setup?
Mine is a 2.25” level, two spacers up front, one top of strut and one sitting bottom of strut. I don’t see and spacers under your strut at all. Please take it in immediately making sure you do not use 4X4 until it’s raised OFF from the lower control arm
I have a spacer on the top of the strut and one under the strut, if you zoom in to the pic you can see the black Rough Country spacer under the strut, 2.5” kit
Edited by Arkangel
Ok, your last pics don’t show it really touching. Close but not touching. Those rubber booties turn as you’re using 4X4 so you do not want them touching. The pics may be an illusion, if you can put your finger between the two then you should be good just do not want them touching.
    • She's laughing all the way to the bank.
    • There's a new PI on 2023-2026 L3B shudder.  Possible faulty front oxygen sensor.   Dealer can pull up PIP6060A and give it a read.
    • Also here's the drive cycle for a 2021 Yukon with V8.  DO NOT USE THE CRUISE CONTROL WHEN RUNNING DRIVE CYCLE!!!!!:   Warning: Road test a vehicle under safe conditions and while obeying all traffic laws. Do not attempt any maneuvers that could jeopardize vehicle control. Failure to adhere to these precautions could lead to serious personal injury and vehicle damage. Note: You have completed this procedure when all parameters display Complete. Short stops for traffic will not affect the procedure. Note: Do NOT use cruise control during this procedure. Ignition/Vehicle » Off — For greater than 8 h Verify the scan tool parameter: Cold Start-Up = Yes If not the specified state Ignition/Vehicle » Off — For greater than 8 h & Repeat this step If the specified state Ignition » On / Vehicle » In Service Mode — For 1 min Engine » Idling — For 2 min Drive the vehicle while maintaining the following conditions for 20 min: Part Throttle Vehicle Speed = 24 to 97 km/h (15 to 60 MPH) Safely stop the vehicle Operate the engine/vehicle within the following conditions: Accelerate the vehicle to 64 km/h (40 MPH) Accelerate the vehicle from 64 to 97 km/h (40 to 60 MPH) @ Throttle position between 10% and 13% Release the accelerator pedal and let the vehicle coast down with the brake pedal released — For greater than 20 s Accelerate the vehicle from 64 to 97 km/h (40 to 60 MPH) @ Throttle position between 13% and 16% Release the accelerator pedal and let the vehicle coast down with the brake pedal released — For greater than 20 s Accelerate the vehicle from 64 to 97 km/h (40 to 60 MPH) @ Throttle position between 16% and 19% Release the accelerator pedal and let the vehicle coast down with the brake pedal released — For greater than 20 s Accelerate the vehicle from 64 to 97 km/h (40 to 60 MPH) @ Throttle position between 19% and 22% Release the accelerator pedal and let the vehicle coast down with the brake pedal released — For greater than 20 s Accelerate the vehicle from 64 to 97 km/h (40 to 60 MPH) @ Throttle position between 22% and 25% Release the accelerator pedal and let the vehicle coast down with the brake pedal released — For greater than 20 s Maintain steady state throttle at 89 km/h (55 MPH) — For 10 min Safely stop the vehicle
    • About the only GM that compares well with its competitors through the small to midsize vehicles is the Trax. I would like nothing better to just drive GMs. My wife in a Cadillac me in a Chevy minivan and Colorado. Part of my day is comprised of reading and watching comparisons of automobile. I could buy a car today. I’m back to research the next.
    • Do you have any DFM defeat devices like the Range modules?
