23 hours ago, EDL said:
Are you guys that are adding the 2" to 2.5" leveling kits also adding a diff drop?
No need for a diff drop to do a 2-2.5" level.
Ok, thanks, was just curious.  I did some reading and watched some videos of the installs and in many cases they still recommended a diff drop just to try and keep the CV angles as close to stock as possible.  Heck, from the videos, the drops were only spacers and not terribly difficult to install.
I learned the hard way many years ago about drive shafts, drive angles, u-joints and such when I used to jack my trucks to stupid levels, so maybe I'm just being too sensitive :-)
On 6/13/2018 at 6:45 PM, dougwtx said:
2018 GMC 1500 Crew Cab SLT with 3.5" Superlift kit.
this looks perfect to me (height-wise). how are you liking the lift so far? How does it do on the highway? Looks awesome!
Thanks!  It rides great.  90% is highway use.  It rides just a tad stiffer than stock.  It does have the Superlift shocks in rear that came with the kit and a Hellwig 7886 rear anti-sway bar was added.
perfect thank you!! Seems like the 18's are gonna have to get a new UCA's regardless of what you want to run. I wouldn't mind getting rid of the ranchos all together and getting bilsteins all around (with the superlift UCA's) or something. Eitherway, looks awesome!!
I'm still undecided which way to go. I'm leaning towards the RC 2", but has anyone installed the Rancho Loaded quickLIFT strut assemblies? It gives you 2" up front plus 9 position adjustable shocks and struts.
This looks really nice. Installed yourself? From what I read in the Superlift site, it comes with spacers for the diff too so the diff does drop down slightly, right? Stock front shocks?
Edited by '17 Sierra
Thanks!  I had a shop do the installation.  Yes, it comes with spacers to drop the diff.  Front shocks are factory.
2.5 RC Level on 34's (she needs a bath)
What’s the actual tire specs? Factory wheels are you running spacers?
the actual specs say 33.8" so were rounding up here. it rubs at full lock both forward and reverse so im looking into 2" spacers until I can find a set of wheels I like
It looks good I want to level mine and leave the factory wheels and run spacers and a bigger more aggressive tire. What is the actual size (example 295/55/20) that’s what I was looking for
285/60/20 I like a wider tire rather than taller. I know some people on here run a 275/65/20 which is the stock width and just beefier. im not a fan of chevy's big wheel wells, cant fit a big tire in there to close the gap with out doing some mods.
    contrabombarde
    contrabombarde
  • Who's Online   4 Members, 0 Anonymous, 1,407 Guests (See full list)
    • Some clarification may help with some of these issues.   - Rev Industries is/was the division of BAK (now Realtruck) that makes covers under the OEM names.  So if you see one with a Ford logo on it, or if you are buying the GM Accessories cover, you are essentially buying a BAK G2 cover with different branding.   - Rev Industries now markets under RealTruck "Advantage."   - As of May 1, 2025, the Advantage covers now have a 5 year warranty.  Anything before that was a 36/36K warranty.   - Parts for the covers are available from Realtruck or BAK.  The email address to reach them is [email protected] or you can call them at 818-365-9000   - If the entire cover has to be replaced, you have to go through your local GM dealer.  Service dept opens an RO, notes the damage and submits it as a warranty claim.  Keep your paperwork handy so they can confirm when you purchased it and it's within the warranty timeframe.  Once the warranty claim is approved, Parts orders the replacement cover.  When it arrives at the dealership, service will remove and install the new one for free as labor is included under warranty.   - The Advantage covers are not the latest and greatest Gen 3 covers.  They still use the old school clamps, elevator bolts, etc...If you want the newer technology, consider buying your cover in the aftermarket world.  That way, if you have an issue you can deal directly with the manufacturer.   - Finally, RealTruck has a program with many of their authorized dealers that doubles the warranty to 10 years if the authorized dealer does the install.     Hope this helps.
    • Welcome to the group!  My '22 just crossed 150K miles.  Runs perfectly.  Oil pump belt will be done in the next 30 days or so and onward hopefully for another 150K.  Love the truck.
    • Still looks like a rivet to me in the pics, I don't see a nut and none of the pics show the head of the screw. But if you says so.....
