I ended up giving up and busting one of mine up really good with a pickle fork (was putting on new UCAs anyway).
I've always broke themapart with a hammer on other trucks, but couldn't get this one to budge. I let it hang for an hour after hammering. Sprayed it with penetrating fluid. Cranked the wheel back and forth. Beat on it from every direction and every height (jacked the lca up and down at various heights) and never could get it to bust loose with a hammer. The passenger one came apart much easier. Not sure why this one was so much harder.
For those who've done their own leveling kit:
I've done several on my previous vehicles, and a fair amount of front end work in college, but.... I attempted to pop the upper ball joint this week, on my new Silverado, and it wouldn't budge. I used a pair of 3# hammers (one one the left side of the knuckle, the other swung from the right, and vis-versa.) Nothing! Puppy is holding fast!
A friend suggested that the knub on the back side of the knuckle was the appropriate target point... what's your experience?
Maybe try putting a jack under the knuckle and jack it up a little bit. Then try whacking it with a sledge.
Same here like the others have said. Right side popped off but the left side wouldn't no matter what I did. I was able to get the spacer in the left side without dropping the ball joint. PITA, but I got it. Also, I don't believe it's necessary to disconnect the electric steering connectors either. Those clips break super easy. Ask me how I know..
How did you install the spacer without popping the upper ball joint? I thought about trying to compress the strutt with a bottle jack while the suspension is at full droop.
With the opposite side still up in the air with both sway bar links disconnected, you can disconnect the bottom strut bolts and loosen the top strut bolts and just about get the spacer on without compressing. I tried that, it would have worked if I would have had a second jack or a second set of hands to help compress the shock or the coil/upper arm.
But getting the nut on the lower strut bolt that sits under the 4wd axle will be interesting if you don't drop the knuckle.
Edited by Mattvand
You put the bolt in from the bottom on the axle side.
Lots of persuasion! With the RC kits being polymer, once you get a corner of it started, they tap in the rest of the way fairly easily.
Edited by '17 Sierra
Nice setup. Love those tires! Any room for larger size?
Sorry never saw this, I think it can squeeze 35's just fine! Masbe with some slight trimming.
RANCHO RS999901
Has anyone used this to replace the entire strut assembly to level my truck? I can do this easily. Otherwise I was going to go with the Bilstein shock replacement and have to get a spring compressor and all. Thanks.
RANCHO RS999901
I have heard good things about the rancho quick lift other than they get rusty fast.
I want to get them as well but not sure if I'd rather get the fox ones.
Ordered the Rancho Quick lifts and matching rear shocks. I like the ease of install and not having to dismantle the strut. Should have them tomorrow and install them over the weekend if I have time. I've switched out strut assemblies before on many GM trucks. Shouldn't take more than a couple of hours.
Edited by raress9596
Hello everyone, I have a 2014 Sierra 1500 SLE and installed the Bilstein 5100's on all four corners. You don't have to change the rear shocks if you don't want to but that's up to you. You will need an alignment. The stance to perfect with an 1/8 of inch. Ride has since gotten better and more comfortable. Hope this helps.
Ordered the Rancho Quick lifts and matching rear shocks. I like the ease of install and not having to dismantle the strut. Should have them tomorrow and install them over the weekend if I have time. I've switched out strut assemblys before on many GM trucks. Shouldn't take more than a couple of hours.
Can you do measurements of the amount of lift it adds, the rancho page says that it will make your truck able to run 35s but doesn't say what it needs to be paired with if anything.
I found only one video of a guy running 35s with them.
    whenindoubtuseahammer
  • Who's Online   3 Members, 0 Anonymous, 427 Guests (See full list)
    • Its no wonder you've gravitated to the oil types and brands you have in later years after trying certain brands and one being a specialty oil or at least very hard to come by up here and the other would have been a commonly found oil of the era and the vastly different outcomes as a result to using the vehicles in question the same distance for an OCI . It shows what marketing hype can do without actually having the product to back up the claims and that is no different now with the insane claims that are written on the side of a bottle of oil from some of the off the shelf oils.    What has surprised me and I was already finding this out before I bought my truck with the GDI engine, that this newer fancy technology that seemingly would suggest better fuel economy/emissions with this high pressure spray of fuel is not in reality kind at all to the engine or at least the oils life. Yet they insist on claiming long OCI with this technology just like they did with the port or similar type fuel injection systems when in reality its a step back in oil life to have a GDI system.    I think the mistake your making Grumpy is that your not sending your samples to Blackstone and getting the feel good glowing report that you can run it another 1000 or more miles and then send another sample where they say run it yet another 1000 miles and on and on it goes until your sending in something that looks a lot like road tar and then they may suggest you change your oil within the next 1000 miles 😆
    • I am guessing that engines of that design back then had a better ability to be abused and survive longer than a new design engine with the long timing chain and the overhead cams and phasers etc. But I would never guess that an engine could go that far and not fail spectacularly or at least die a slow death.
    • In the 80's 90's I'd run Honda's 7,500 miles between changes using Red Line HP 5W20 and do it for hundreds of thousands of miles with issues. Back in the day it was an SAE 20 with the HTHS of a SAE 30 and SN add load. It was also very polar. Oxidation VOA was over 120. Besides those motors were SPFI and lean burn tech. I could have likely run it longer but never did.    We had a Toyota bought new I ran on Pennzoil's latest and greatest synthetic of the day with "Penthane". A made up word for a very low dose of PAO. Tried 7,500 mile OCI's in that Group III/VI chemistry and the rings tapped out at 90K. Rocker box wasn't as bad as the one Punch put up but it wasn't good either. Also a SPFI motor.    I'm around 3,750 across the board on these GDI monsters and the oil it tapped out by then usually on TBN/TAN crossover and color. Red Line HP Euro.    The AMSOIL SS brochures tell you to follow the OEM values for the service class but that it can be run up to 25K if monitored. I can't imagine what motor could go that distance and not tap out. I've never owned one.    Yes, I know. Lot's of people do. I'm just not going to be one of them.
    • I knew a guy in the early 80's that bought a new Monte Carlo and ran it a 100,000 miles without ever changing the filter or the oil. Just kept adding. It looked like that inside.
    • Good evening. I was lucky enough to get passed down to me a 2007 GMC LBZ that was my great uncle's. While the underside and rockers are more or less gone I feel like with time I can restore it to working order since it only has 110,000 miles and he put nearly every option he could get without getting the new body style since he did not trust DEF. So far I have done everything I can think of but when I put the key into the ignition nothing happens. I put 2 brand new batteries in it. Cleaned the terminals. Check all the fuses and relays and they all pass with my multimeter. I know I'm missing something that I just cant think of. The only odd thing is the OBD2 port works which makes me think its not the mega fuse. Any advice would be greatly appreciated.
