Has anyone found a 2.5" lift / level that works properly in the 2017 GMC Denali with the Magneride ? I have called everywhere locally and keep getting mixed answers. I want to be sure before I start messing with it. Thanks for your help in advance !!
Here is my Sierra. 2.25" Readylift leveling kit. 20x10 wheels and 305/55r20 Toyo all terrains.4653782a64447af95191a6ce45c4eb06.jpg
Sent from my SAMSUNG-SM-G890A using Tapatalk
  • Like 4
Denali with Magneride ?
No Magneride, just an Elevation edition.
thats an all terrain
2017 Chevy Silverado LTZ Z71 6.2L
4.5" Zone
22x10 AF Grips
33x12.5 Nitto Ridge Grapplers
Instagram @wildchevys
Suspension Maxx shows this leveling kit for 2015+ 1500 Denali with Magnaride suspension.
https://www.suspensionmaxx.com/store/product/SMX-GM725M
Yup that's the one I was looking at, but rough country said if I use their Version that uses the top shim too that it may overextend and damage steering linkages ? Do I trust rough country or suspension maxx ?
I have the Rough Country 2.0" level kit on my 2017 Denali with Magneride, installed by the dealer. Zero issues, rides like factory or better. Truck is also perfectly level. No rear blocks.
http://www.roughcountry.com/gmc-leveling-lift-kit-1311.html
http://www.gm-trucks.com/forums/topic/168618-leveling-kit-for-2015-sierra-denali-magnetic-ride/?fromsearch=1
This thread has several members who have used the Suspension Maxx level kits on 15+ Sierra Denalis with no issues. One member used Ebay spacers and fabricated his own Magnaride sensor relocation bracket for less than $30. Good luck with whatever you choose.
Is this specific to 2017 Denalis? I've got the rough country 2.5 lift/level kit, any reason I shouldn't put it on my '17 with magnaride?
I searched this thread for days upon days looking at all the pictures you guys post of your rides and comments about everything before I did anything to my 2014 Z71 and I was wondering if anyone has pictures of an installed 2.5" RC Lift/level kit with and without blocks in the rear to see the difference it shows.
As long as you have the version intended for Magnaride it should be fine. The main difference is that it comes with two little brackets that adjust the magnaride sensors to account for the lift. Very straightforward. You CANNOT use a regular lift/level kit on Magnaride without these, or your truck will drive like a dump truck.
According to rough country there is nothing for 2017 Denali specifically only up to 16 which doesn't make sense to me ? What did they chance that makes such a difference in 17 ? Only difference I have found is that they went from aluminum control arms to stamped steel ?
This is the problem ... only change was the stamped control arms .. now they say you can't use the top spacer & they don't have a kit for the rear .. just 2" level kit for the front ... frustrating to say the least.
    Sothpaw27
    Sothpaw27
  • Who's Online   2 Members, 0 Anonymous, 449 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
