I actually did that on Bluebeam. They're just colored shapes with the opacity reduced.
I have the same wheels, and I always thought they would look bad ass in black....that photoshop pic confirms it lol. I also thought of keeping the textured rectangles on the five spokes silver....but I suck at photo editing to see how that would look. Maybe all black and leave center cap and lugs silver? I love the look of this particular wheel and I wanna keep them but I want black.
Black Denali a friend with a 2015 Sierra Denali has the OE 22's with Toyo Open Country MT 33x12.5x22. I know it's leveled in front but not sure if he is running a 2 or 2.5 inch kit.
Any chance of a photo or two of that truck ?
Any official info regarding what are the largest tires that fit on the stock 22" rims ?
I'm having a hard time finding any other sizes wider that stock in a decent looking tire meant for a truck
hey, what i did was use this site:
https://tiresize.com/converter/
it is a tire size converter...so i would plug in a known size that works....and then on the comparison portion, put in your 22" rims and play around with it...so then you have a range (albeit probably small range) of tires that would work...you have a baseline of sizes to shop for...then next truck (which i think you are finding out now) is finding a size that is actually for sale, that matches what you discovered.
hope that makes sense...but i will give an example...my old '08 had 275/55r20 on them...i knew that size would work...so then i plugged in my new 18" rims...and found out that a 285/65r18 is almost the exact size, so i could could say without any further research, that size was a reasonable option, then i got on this board and just confirmed. (also i know that street tires and all-terrain/off road tires aren't a 100% apples to apples, but i think you get my point) but you could plug in a known tire from someone that you know has that same lift...and back into it...
hope that helps! good luck, cant wait to see pics!
Yeah I have been using it !! It's pretty good!! The biggest limiting factor is the 22" rims lol not much in a beefy looking truck tire
yep. as much as I like those rims for a 2wd...(no offense, personal preference) but for a 4wd, I'm not even much of a fan of 20" rims...and there are a TON of people here that might chastise me for that opinion! haha! but again, I only have a leveled truck, not lifted...so that makes a difference too...good luck, surely there is something out there that gives you at least a little bit of beef! haha!
None taken man !! We all like what we like. I wouldn't have bought a Denali if I wanted an "offroad" looking truck. I just want a beefy looking street truck ! I really do like the look of the 22" ultimate rims and I know not everyone does, so I just gotta find a decent looking set of tires that are slightly oversized. 305/55/R22 seem to have a couple options & 33/12.5/R22 might work but only option I have found are the toyo open country which are insanely overpriced where I have found them.
The search continues...
would 305/45r22 be too small? that opens up your options...
Hey all,
Just created an account and got setup! Just been reading on these pages and getting familiar with the varying setups you all are running. Thanks for all the great information! First, part of me wishes I would've went 2016 front end+, so sharp with the ptm bumpers in white (originally wanted a Sierra SLT, but the Canada truck got sold out from under me)! That said, I picked up a 2015 5.3L Slate Gray CC SB LTZ fully-loaded last December. Since then I have added 2" RC level, Westin HDX Xtreme nerfs, 13% tint, spray-in bedliner, tonneau cover, MBRP exhaust, upgraded headlights to LED bulbs, & Husky floor mats (which I love over WeatherTechs for once).
Now the next step for me is to add some new shoes. I had 2011 F150 FX4 Eco CC prior and ran 2" Autosprings level and 295/60R20 Nitto Trail Grapplers. Loved the look, but hated the completely ruined and rough ride with the E-rated tires with the huge MPG losses as well (I went from mid 20's with my 3.5 TT to 12-13 city 15-16 hwy...didn't think it was going to be so steep). I believe my stock 20's, which I believe I am going to keep, run +27mm correct? I am seeing guys running 285, 295 and even 305s all stating just swaybar and UCA rub much like my F150 setup. I don't want to go as aggressive with a MT again nor E-rated if possible to stay more toward stock ride.
My questions are:
1) Are there any tires existing that have the more aggressive look without going E-rated and the 50 to 80lb/piece? I see the Nitto Ridge Grapplers are like 60lbs/piece and a bit lighter with fairly aggressive tread
2) If not, I am thinking clearly the 285/65/20 or 285/55/20 BFG KO2's are a likely candidate (think I like the white-wall better, but from reading don't believe are still available). Or some Toyo AT2's (Xtreme), Nitto Ridge Grappler, or GY Duratracs.
3) If having to go heavier, does the 5.3L handle it well? expected MPG losses? I removed the upfront dam/valence as well when leveling.
4) Would the 22" OEM Denali wheels bolt on or anyone do that to their chrome package Silverados? Saw a few Sierra's rocking those and I love the look and gunmetal appearance. Just not sure how that would mesh with my current chrome. Pics?
Any other 20" OEM chrome setups and pics would be greatly appreciated! Thanks in advance!
Edited by kirschbaumr
Sorry Black Denali no pictures of it but I concur those tires are expensive????
If you don't want to go to a full 33x12.50, then look into 285/50/22 and 305/45/22. A 285/55/22 would look sweet, but would probably rub.
Yea, I just googled searched them and actually found a used set with very slight scratches with start out at $1,600. Reasonable?
    • In the 80's 90's I'd run Honda's 7,500 miles between changes using Red Line HP 5W20 and do it for hundreds of thousands of miles with issues. Back in the day it was an SAE 20 with the HTHS of a SAE 30 and SN add load. It was also very polar. Oxidation VOA was over 120. Besides those motors were SPFI and lean burn tech. I could have likely run it longer but never did.    We had a Toyota bought new I ran on Pennzoil's latest and greatest synthetic of the day with "Penthane". A made up word for a very low dose of PAO. Tried 7,500 mile OCI's in that Group III/VI chemistry and the rings tapped out at 90K. Rocker box wasn't as bad as the one Punch put up but it wasn't good either. Also a SPFI motor.    I'm around 3,750 across the board on these GDI monsters and the oil it tapped out by then usually on TBN/TAN crossover and color. Red Line HP Euro.    The AMSOIL SS brochures tell you to follow the OEM values for the service class but that it can be run up to 25K if monitored. I can't imagine what motor could go that distance and not tap out. I've never owned one.    Yes, I know. Lot's of people do. I'm just not going to be one of them.
    • I knew a guy in the early 80's that bought a new Monte Carlo and ran it a 100,000 miles without ever changing the filter or the oil. Just kept adding. It looked like that inside.
    • Good evening. I was lucky enough to get passed down to me a 2007 GMC LBZ that was my great uncle's. While the underside and rockers are more or less gone I feel like with time I can restore it to working order since it only has 110,000 miles and he put nearly every option he could get without getting the new body style since he did not trust DEF. So far I have done everything I can think of but when I put the key into the ignition nothing happens. I put 2 brand new batteries in it. Cleaned the terminals. Check all the fuses and relays and they all pass with my multimeter. I know I'm missing something that I just cant think of. The only odd thing is the OBD2 port works which makes me think its not the mega fuse. Any advice would be greatly appreciated.
    • Looks nice. I still have my 2000, 1500. Bought a 2025, 1500 for retirement. Feels solid. These trucks have a bad rap on the internet. My brother has a `24 1500, 5.3 with 52,000 miles. No problems at all. Mine hasn`t either but mine`s only at 12,700 miles. Have seen some of these things with 100,000 miles with no problems.
    • Howdy! New to the forum of course! My name is Casey, just picked up a 2024 high country midnight edition. First “new” truck in 24 years for me. Driving a 1998 Z71 since 2002. Have been on the GMT400 forum with lots of good info and help there. Nervous about driving these newer trucks and all their electronics…. Did a lot of work on the Z71 myself over the years. New truck is definitely a nice upgrade after 24 years. Photo of the old and new, still keeping the Z71 - has 320,000 miles on her and still running well!
