23 hours ago, rhill1 said:
Have read a good bit of this thread but its massive. Seeing if i can get some advice. Have a 2017 Sierra SLT with a 2.25" level kit in the front only. Am looking at getting BFG KO2s put on next week. Keep goin back and forth between 275/60/20 and 275/65/20. I keep reading different tires will fit and won't fit. Also the stamped upper control arm issue. The shop that put the leveling kit said they will just put a steering top on when i get the tires. Is that a decent fix or solution to the rubbing issue? What size tires would y'all that have done it recommend? From what i can gather the 17s won't clear as big a tire as the 14 and 15s. Also any advice between ko2 and toyo at2? Any help would be great
You won't be rubbing your control arm with either the 275/60 or the 275/65, they are the same width as the stock 275/55's, just taller. With the 275/65 you may rub the back of the fender, it's considerably taller then stock at 34", which might be too tall for a 2.25" level. There are plenty of people running 275/60r20s on a stock truck with no rubbing. Rubbing becomes a problem on stock offset wheels when you go wider. I've seen plenty of people, including myself, run 285's on a leveled truck with out rubbing, but once you start getting into 295's and wider, it's likely to rub.
My 2015 Silverado had the RHA bilsteins on the highest notch and barely, I mean barely rubbed with 33x12.5x20 Toyo at 2s. Got this 2016 2500hd and put a cognito level kit on it with bilsteins all around and 295/60/20 (33.9x11.6) and don't rub at all. Some one told me the 2500s wheel well is slightly bigger than the 1500s, but I dunno if it's correct or not, look into it, you could possibly fit a 34. Also, the toyos ride smoothe, are pretty quiet, and still look aggressive. Buddy of mine got 75k out of themafd355f71244765089c39645d3030b39.jpg
Sent from my SM-G955U using Tapatalk
Unfortunately this just isn’t correct. I know it should be, because on paper they aren’t wider, but since they are taller, a different part of the sidewall is contacting the UCA’s. I’m guessing you don’t have the stamped steel control arms. I made the mistake of believing what I read on this site, and on my 18, with stamped steel arms, I rub on factory wheels with 275/60r20. I’d love it if I didn’t, but I do.
BINGO! You’re correct sir, same thing happened to me then you’ll need new wheels too. Mine was 2.25” level with new +1 offset 20x9 wheels which then allowed me to have 285/60/20 with slight rub on the inner wheel well liner.
Sent from above
Sent from above
Are all these problems y'all were having stemming from the stamped arms? What is the difference between what was on the 14-15s and the stamped steel ones besides the material? I could Google, but thats no fun. My 1500 was a 15 and had no problems with the 33x12.5x20 toyos, do the stamped steel make that much of a difference?
Angles are different and yes, major difference which them requires new wheel
Sent from above
Angles are different and yes, major difference which then requires new wheel
Sent from above
So how would you correct it, get the 14-15 style arms? Or just a lift and some spacers?
I have 285/65r18. They are 32.5x11.5 No rub. I’ve read that having 20s are different and that you’ll rub with an 11 wide. Some fix it with new control arms.
If you’re going to get a lift then it’ll just work but I’d just get new aftermarket UCA’s and be done with it. Multiple good quality aftermarket uca’s out there, everyone knows my favorite is CST. I hated my leveled truck, had new Bilsteins and still ride Rough. I’ve got the CST 4.5” lift which allows you to keep your stock wheels, your choice up to 35” tires, keeping stock width and turning radius which is extremely rare in any lift. This would be my recommendation but cheapest is $1650 just for the lift plus rear shocks $100 each plus install. If you’re doing a level I’d 100% do a coil over leveling kit with new uca’s which cost same as the super high quality CST Lift. If you’re on a budget, 2.25” front leveling blocks and you’ll need new rear shocks if you add another inch to the rear block.
Imho, don’t rush into this, you’ll 100% regret it! Save up, you never go cheap on your suspension.
Sent from above
Do your homework, do the numbers yourself. Getting new uca’s is no 100% not going to rub. You want as much space for tire flexing as possible.
Level $200 plus
Level requires new UCA’s $500 plus
New wheels $1000 plus
New rear shocks if raising rear which you’ll most likely want to do $200
This is the cost of the badass CST 4.5” lift which keeps every thing stock width not needing spacers and stock turning radius
https://www.newlevelmotorsports.com/cskc3191.html
Sent from above
I had 275/60r20s on my 2017 High Country about a month before trading it in. No level, stock wheels, no rub. Don't know what to tell you. But they weren't a problem. And yes the HC had stamped arms.
(Leveling Thread) It happens due to being leveled!
Sent from above
Sent from above
Yep, this is the key. Mine wouldn’t rub stock, but the level makes it rub
You’d be surprised as to how many people actually put out misleading wrong information out there on leveling and tire size especially 15 1/2 - 18’s. In the past, I’ve called out a bunch of BS’ers claiming their tire larger sizes on these model years didn’t rub when leveled even some saying it didn’t rub cause their tires were already on before the level, lmao! And then find them down the road on another thread talking about their rubbing issues.
People: Leveling WILL cause rubbing issues on years 15 1/2 - 18’s GM 1500’s running 20” wheels when adding anything bigger than stock size tires. Another thing, leveling will cause your truck to ride rougher than stock especially adding E rated tires which is common on larger tires like 285/60/20’s. You’ll also need to buy new offset wheels in order to get the rubbing to stop and buying new uca’s doesn’t guarantee to stop the rubbing which is why I jumped on the “much smoother than leveling” Badass CST 4.5” lift.
When you consider the cost that goes into the leveling parts, wheels, shocks/struts and labor, it’s a no brainer!
You should never “ever” go cheap on your suspension, it’s your vehicles foundation.
Most trucks that are traded in are traded in due to bad riding trucks caused by people that want the look but don’t have a quality suspension, all lifts are not equal, you get what you pay for. If you’re on s budget? Save until you can afford to do it right cause then you’ll actually not only enjoy looking at your truck but you’ll love driving it too and not need a throw up bag and Advil for the ride along
Sent from above
Sent from above
That's rich coming from the wealth of miss information I've seen you post before getting it deleted lol
Edited by Daly
    doylej24
    doylej24
  • Who's Online   4 Members, 0 Anonymous, 766 Guests (See full list)
    • Ok I missed that part that yours is a GM. The strange part is that the choice for year ranges and within the year of 2026 is different on the Sierra then on the Chev for some reason as I am looking at my tool at the Sierra choices. Now I am guessing you see as to your sensor part number as it may be different on your truck for some reason and a call to GM should get you the part model number of the sensors you should have as well as which MHz your sensors are. I know mine are the ones as per what I listed but there are other choices in the Autel and got me wondering if by some chance they put different ones in your truck. Having said that, did you try using each of the choices starting from No 1 and going on down the list, not sure if that would mean shutting off the engine each time and resetting the tool and going at it again each time. Also I thought of something else which may sound retarded but if there was some stupid chance that the chev choice would work. The reason I say that is that the Sierra is showing a range up to 06/2026 for the various choices of sensors it could be where as the Chev has one choice that has that 12/2026. By the way it is possible to not run the truck and you may know that as per not pressing the brake but pressing and holding the start button for a few seconds and it lights up the dash ( its called service mode ) but that sucks battery power and if it were me doing it that way I would be throwing on a decent sized battery charger before doing it that way as killing your battery won't make you happy at me at all !.    Like I say, just a thought to try the Chev choices if you have already exhausted the Sierra choices but first it would be nice to know for sure what exact sensor model and hertz your truck uses as I assume only those choices that mention the sensor would work unless a choice that does not mention the sensor model would somehow work. Its frustrating when one is trying to use tools like this without the experience of the tool and the vehicle, as I am sure dealer techs themselves struggle with it when starting out or a new model year comes along that is slightly different.
    • I tried before I updated the scan tool just incase an update messed it up, but it never worked so I updated the scan tool and it still didn't work.   Only difference is I click on Sierra not Chevrolet cause I have a Sierra.   If I click on 2026-2024 I didn't have any option to change placard, when I click on 2023 it does give me the option but when I try to do it,.it says vehicle not supported!   I have my region or market or whatever it is set to America I think, is that what yours is set to?
    • Its just that it worked on 2024 trucks on this forum and my 2025 model truck, unless GM did something since that point to screw up access or Autel has a bad update. I haven't had need to use my tool since last year when I did the changes to the placard pressure settings and since then I updated the software on my Autel but have not plugged into the OBD so hard to say if I would get a surprise as well.    All I know last year when I bought the Autel I was warned to be sure to update it before I tried using the unit as they said who knows how long ago unit itself was actually manufactured as the software could be way out of date.
    • And so you had gone through the process of registering and updating the tool and so on ?. All I can say is that on the front page as the tool fires up you go to advanced mode, then vehicle model comes up and you choose Silverado ( not the DRW or EV  since your a single rear wheel ) , then I think its choice 2 which is 07/2021 - 12/2026 ( 433mhz 13542523 ) as that is the series of tpms sensors and then go down to choice 5 which is tire type/pressure selection. Hit yes and it says to connect to OBD port and turn ignition on.    Having said this, I updated the software in my tool lately and these year range choices look different from the past due to them doing some updates it would appear and I have not connected up to the OBD port since last year so hopefully I am not in for a surprise with them screwing up the software and that it won't work on my truck anymore either.    So my question is, when you plugged into the OBD and started your truck it had that message on the Autel screen "vehicle not supported" ?. That does seem odd as tire shops would be pissed right off if hey can't use their tool on the model year after mine that in theory is supposed to be much the same truck ... unless GM did some change in the computer system to block certain things from access.
    • Understanding and using modern scan tools is its own body of knowledge. I had little hope that would work...programming access to the BCM is probably required and that is not easy for us consumers. Expensive scan tool, GM programming subscription, online authentication, etc.   It also may be a matter of finding the right dealer to program it for you. Flashing a modern BCM might be a little too advanced for most tire shops.
