It’s compatible but will still rub with anything larger than 275/55r20. Even 275/60r20 will rub. I’ve tried it already. Bought them through amazon so I was able to return but still cost me labor. (This is with the 2.25 readylift level)
A real lift is the way to go, but they don’t make the CST lift for 2wd, so here is where I landed:
1.5 inch motofab level
275/60r20 tires. Rubbed slightly on my sway bar, but my sway bar was offset to one side for some reason. Removed and recentered and it’s all good now. Shouldn’t have that problem, unless you get unlock like I did. The level being smaller allows that size tire without rubbing UCA’s. It isn’t perfectly level but it’s good enough for me and I’m happy with it.
CST does have leveling coil overs but require new UCA’s to be installed too which is a better ride than spacer blocks and replaces your front struts and coils at the same time. This is the same setup I went with before I decided to just do the full lift. The same lift “will” work on your 2wd truck too but has parts you won’t need too which you could sell to someone that would give top dollar for exceptional quality, just a thought.
Sent from above
would you mind posting some more pictures of your truck? it looks great and seems to be pretty close to level
So you changed the level kit to a 1.5" rather than 2.25" and it solved the rubbing on the UCA problem? Is your kit a top strut or bottom strut spacer?
On 3/22/2019 at 7:13 PM, wepiii said:
Unfortunately this just isn’t correct. I know it should be, because on paper they aren’t wider, but since they are taller, a different part of the sidewall is contacting the UCA’s. I’m guessing you don’t have the stamped steel control arms. I made the mistake of believing what I read on this site, and on my 18, with stamped steel arms, I rub on factory wheels with 275/60r20. I’d love it if I didn’t, but I do.
question on this.. if your rubbing on the factory 20's wouldnt a 1" wheel spacer give you more than ample clearance and give you a minor wider stance? also if so would that not allow you to go to a wider tire as well ? just curious.
Edited by no12nv
On 3/8/2019 at 2:41 PM, mrskiff said:
Changed my setup a bit.
Motofab 2.5" up front
Motofab 2.25" blocks in rear
Readylift UCA's
305/65r18 BFG KO2's
18x9 -12 Black Iron Wheels
Zone fender trim plates to fit the tires. Fenders measure 40.5" up front and 41.5" in rear. Need to wash truck and get some better pictures.430db37d067c71dbcaf89b385e1921cd.jpgebf0e3caffe942d13affc36ffff84ce8.jpg
Sent from my SM-G950W using Tapatalk
i cant find motofab 2.25 rears? were did you get them ?all i find is 2"  wonder what mine would be like on stock 22s
. thanks
Edited by no12nv
On 3/6/2019 at 6:52 AM, krychrt said:
I went with the ReadyLift 2.25 up front and swapped the rear 1.25 for the ready lift 2.25 based on the recommendation of those above. Came out good I think. If anything I would have liked a little higher in the front but matched with the new KO2’s its like a new truck. Ride quality seems unchanged so far as well.
i see what you are saying in the front.. how much rake/height diff do you have now as it sits?
1.75 is the smallest you can go without having to trim your factory studs which I just don’t wanf to do.
. thanks
They are on their website. 1 inch rear lift. So 2.25 inch block
Sent from my SM-G973W using Tapatalk
I would say about an 1” lower in the front at the most maybe less. I will measure for you
Forgive me if this has been discussed, but I have an ‘18 Z71with 18x8.5” stock wheels. I see a lot of guys talking about rubbing with leveling kits but they’re running the 20” wheels. So if I were to put the 5100 ride height adjustable on the front, which height would get me as level as possible? 1.26” or the 1.85”? Also, once I have those installed, would I have any rubbing issues on ucas or anywhere else?
no clue.  what size tires are you asking?
i have stock 18" rims, run 285/65 KO2s and no rubbing on a level...
For now just the stock 265-65-18, once these tires are worn down I'll replace them with some all terrains but not sure of size just yet. Definitely want something that looks a little more beefy than the stocks. Looking at your profile I like the look of what you're running. What level did you use? I installed the bilsteins on my ford just over a year ago and loved them, so I'm leaning toward putting a set on this truck as well.
when they talk about rubbing...they are talking about upgraded tires, never talking about stock size tires...a level will give you more room not less...so if you are stock specs, you should never have to worry about rubbing...
my set up is a RC 2" front level, rear stock, stock rims as i mentioned the tires i have...i really like the set up...i don't need anything crazy aggressive for the amount of off road use i do...
as far as bilstien's go, i am considering replacing my stock shocks (front and rears) with them whenever i need to replace them...there are dozens and dozens of guys on here that recommend them...they seem to be probably the best value of upgraded shocks before you start spending some serious cash...
    • Replace the fuel pump with an OEM AC-Delco.
    • Hello, first time posting here. I have an 03 Chevy 1500HD with the 6 liter gas engine. The truck ran fine until the fuel pump died on me and had to get it towed. Replaced the fuel pump with a precision pump from O’rileys and changed the fuel filter while I was there. The truck will run and drive now but it wants to idle around 500 rpm when in drive and it tries to stall if you touch the gas. It drives fine though, just doesn’t want to idle. Put a fuel pressure gauge on the rail and only have 50 psi. I guess these trucks should have 55-62 psi to run right. I thought the regulator might be the issue because when I would unplug the vacuum hose it jumped to 56 psi. Replaced the regulator and no change. The only thing I can think of is that I was sold a faulty fuel pump. Any help would be appreciated because I’d rather not have to take the bed off again if I don’t have too. Thank you!
    • I've been wrenching on GM trucks for 17 years. And I need to get something off my chest because it's been weighing on me for a long time. After all that time, all those motors, all those people standing in my bay, I've figured out there are really only two kinds of owners. The ones who already know about this. And the ones who are about to find out the hard way. A guy came into my shop a few weeks back in a 2018 Silverado 5.3. Sharp guy, maybe 35. Knew his truck cold. He'd been on the forums, read the threads, done his homework. He only rolled in so I could double-check a little module he'd already plugged in himself. Wanted a second set of eyes on it. Ten minutes, in and out, drove off happy. Two days later, a completely different story walked through the same door. Older fella this time, in a 2016 Sierra. Gorgeous truck, clearly babied, not a scratch on it. Wedding ring. Looked like a guy who took care of his stuff. He was in because his engine had started knocking on the way to work. And by the time I got the valve cover off, I already knew it was too late. Lifter collapsed. Cylinder 5. Camshaft chewed up. The whole top end shot. Same kind of truck. Same motor. Same roads, probably the same dealer. The only thing separating those two men was information. I've been at this since 2008, and I've worked on everything GM puts out. Silverados. Sierras. Tahoes. Yukons. Suburbans. Escalades. The 5.3 and the 6.2. Doesn't matter which badge is on the tailgate. They all carry the same problem. So here's the information one of those guys had and the other one didn't. It's called Active Fuel Management. AFM. GM started building it into their V6s and V8s back in 2007 to squeeze out a little better mileage on the highway. Maybe a mile or two a gallon. All to hit government fuel economy numbers. The way it works, the motor quietly shuts down half its cylinders when you're just cruising along. And the little lifters that pull that off have a tiny pin inside them that's constantly clicking in and out. Lock, unlock, lock, unlock. Hundreds of times a drive. Thousands of times a week. Eventually one of those pins wears through. The lifter drops. And it starts grinding the camshaft down like a chisel on butter. And what nobody tells you is that the shudder you feel around 40 or 50 mph? That's the system cycling. Every single time. Here's what really gets me. The pre-2007 trucks, the ones without AFM, they're bulletproof. I've got customers still daily driving them with 260,000 miles on the odometer. Not a problem in the world. GM took a perfectly good motor that would have lasted a lifetime and bolted this system onto it. And it is wrecking engines that should have run forever. The guys who hang around the forums already know all of this. So do the techs. They handled this years ago. They didn't sit around waiting for the dealership to mail them a warning letter, because that letter is never coming. It's the guys who figured somebody would've told them who end up on my lift. And I want to be clear, because this part matters. Maintenance has nothing to do with it. I've torn down motors with barely 30,000 miles on the clock. I pulled apart a Tahoe last summer with 24,000 on it. Practically a brand new truck. Owner had it less than a year. Spotless oil. Best synthetic money can buy, changed early every time. Made no difference. I've seen guys with full dealer records, every interval stamped. Made no difference. The oil changes were never the problem. The pin was. And no amount of babying that truck stops that pin from cycling every single time you drive. That's the part that eats at me. These are good motors. Take the AFM out of the equation and a 5.3 or a 6.2 will run 300,000 miles and never blink. So a few years ago I started telling every single owner who comes through my doors the exact same thing the smart guys already knew. Get yourself a FullForce disabler. It plugs right into the port under your dash. Couple of seconds and you're done. It just tells the computer to leave every cylinder running, full time. No more cycling. No more beating those lifters back and forth every time you turn the key. It doesn't reprogram anything. Doesn't touch your tune. And unplug it before a dealer visit and there's absolutely zero trace it was ever installed. I've had customers come back at 40,000, 60,000, 80,000 miles after I put one in. Zero issues. The trucks run smoother. And the lifters aren't getting beaten to death every single drive. I won't sit here and tell you it's magic. A lifter that's already damaged is a lifter that's already damaged, and this won't un-ring that bell. But it takes away the one thing causing all that wear in the first place. That's the whole game. You don't need a five-thousand-dollar delete. You don't need an expensive tune. You don't need to tear anything apart. You just need to stop the cycling. I'm not writing this for any company. I'm writing it because I'm tired of watching the guys who didn't know pay four and five figures for it. I'm tired of being the guy who has to break the news. I'm tired of knowing that the guys who did know fixed the whole thing for the price of a tank of gas, and the only difference was that somebody told them first. If you drive a Silverado, Sierra, Tahoe, Yukon, Suburban, or Escalade from 2007 or newer with a V6 or V8, you've got AFM. You've got those lifters, and they're cycling every single time you drive. So be the guy who already knew. Not the one I'm scraping metal out of next month. EDIT: A bunch of folks asked, so here it is. The one I put my faith in is FullForce. This is where to find it: https://www.tryfullforce.com/products/fullforce™-afm-dfm-disabler They back it with a 60-day guarantee too. I've handed out more than I can count and not one's ever come back to me. Not one. See less
    • Thanks for following along. I'm not author material, my tenses are all over the place and an editor would have a heck of a time cleaning up after me. Reading and writing is still a fun pastime though.   My new scanner came in yesterday, wow, where the heck has this thing been?! It connects right up to the Blazer, there's all kinds of bidirectional tests like EGR activation and percentage, toggle the fuel pump relay, EVAP purge valve, IAC control, AC relay, reset the transmission's adaptive learning, toggle shift solenoids and TCC lockup, and I can reset fuel trims with the click of a button...all things I could have used over the last 60 days!   It's also telling me there is a stored code in the ABS module for front left wheel sensor open and something about the brake switch. The ABS dash light works. It illuminates normally during the self-test at key on/ start and that's it. I cleared the codes and will see if they set when I take it out later. That, and I'm going to get (hopefully) real data on timing and cam ******. The PID's are there.   I connected the tool to my truck...holy smokes. Newer vehicles make early OBDII vehicles look like 8-bit, pixelated, early Nintendo stuff. This? This is like wearing 3D virtual reality goggles playing one of those elaborate, cinematic video games with seasons and plots in comparison. There are SO MANY modules and SO MANY tests and SO MUCH data. There's a scanner sequence for filling the coolant...   End of the day, it's a tool with way more power than I need, but the versatility to do old and new is there (and I need an adapter to connect it to my OBDI Camaro). It will allow me to do the first pass of diagnosis when out-of-warranty vehicles need help, and it will enable more DIY maintenance like brake system bleeding, ABS bleed, etc. I probably over-bought here, but, mission is accomplished.   Enjoy your Sunday...I need to shut this machine down and go get ready for the week ahead.
    • Not that I've read, after all the issues they've had in the past I'm pretty sure they learned their lesson.
