2nd link isn't working. But the first link is what the lower spacer is supposed to look like. Looking up the 1303 kit in the second link I saw is the 2.5" kit so maybe your talking about the top strut spacer? It's kind of like a triangle with rounded sides more or less.
Not sure why the link did not work in my original post but it seems to be working in the quote on your post. I am not at all concerned with the upper strut spacer I fully expected that because that is one of the main differences between the 2" and the 2.5" leveling kit. However, if you look closely at the two different kits you will notice that the lower strut spacer is different. The lower strut spacer pictured with the 2.5" kit has a constant thickness where as the lower strut spacer pictured with the 2" kit has a variable thickness.
The one you received just looks to be maybe an older style or design. What does the materials feel like? The ones you expected isn't plastic, but feels kind of like a plastic. As said, it looks like it does the same thing and the fitment guide for it says it fits from 07-present 1500s so it should fit. Maybe someone sent you an older kit.
I agree with SouthernSilveradoGuy85. I believe I received an older style spacer. The material does feel like a plastic but I know from reading other posts in this thread that it is some type of glass resin composite. I will be calling Rough Country tomorrow to see what they have to say. Hopefully their literature is out of date and not my kit.
The first link in your message is to the 2" kit. The second link is to the 2.5" kit. Did they send you the wrong kit?
They stick out maybe a quarter inch. I have fuel maverick 20 wheels with +14 offset. No wheel spacers. Lift is a 2.5 Rough Country front only . 1af906e391628974ab1c87be8ebc056f.jpg50a7536706c5c480a8ab67877c9aa116.jpg7c2e731cb990e9a6ac802a842f366df4.jpg
How tall is the wheel well now up front? I want to do a larger lift on my truck but have a feeling I may do something like this. It's simpler and still looks great.
Hello ladies and gents,
I recently got an RC level and I tried installing it with help from a friend, but we ran into a problem.
The aft strut bolt hole sits directly below my front driveshafts. I can post pics of necessary but does anyone know what I can do about it without removing the upper ball joint entirely?
I ended up removing the ball joint nut completely and putting the new bolt in from the top so I wouldn't have to worry about it ribbing on the shaft.
Click on the link below for pictures.
"I had the same issue, one of the bolts would hit the CV shaft if I installed it with the head of the bolt on the bottom per the instructions from Rough Country.
With the upper ball joint and steering linkage ball joint disconnected I was able to tilt the hub assembly enough to get the CV shaft out of the way and then put the bolts in with the head on the top side and nuts on the bottom. Here are some pics.
http://www.gm-trucks.com/forums/topic/153363-2014-leveling-kits/?p=1505852
Edited by 15LTZZ71
Here is mine 3" front and 2 1/2 rear block which gives it 1.25 of lift in the back. It has a very slight rake. Not sure how much. post-135776-0-88526500-1415339081_thumb.jpg
No leveling kits for the 2015 Denali 1500.
After speaking to Rough Country and BDS Suspension, a leveling kit for the 2015 Sierra 1500 Denali is a NO-GO. They said the magnetic ride suspension measures the vehicle rake and a leveling kit would throw it out of whack.
They said to try back after the new year and maybe they will have figured it out. Maybe will require reprogramming of the mag ride?
I'm kind of bummed about this. My truck should be here in two weeks and that was one of the first things I planned on doing. I'm very much looking forward to the mag ride though. We'll see....
I leveled the front with a 3" kit from CCm Offroad (The kit I used fit 2007-2014), I also have air bags in the back I tow a trailer and didn't want the back to sag. the tires are cooper neon ltz 305/55r20
I also painted the center caps of the rims to match the rims. De badges and tinted the windows.
Anyone know if a 33x12.50x20 toyo open country rt will fit with a leveling kit without rubbing
That is exactly what I am running. I have a 2.25" level. I don't rub.
    Sothpaw27
    Sothpaw27
  • Who's Online   0 Members, 0 Anonymous, 439 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
