I had them put on yesterday, so I haven't had them all that long. I really like them!
bought a one inch kit off ebay billet aluminum half in spacer for lower aframe very easy install 20 minutes no tire removal no ball joint nothing drop the two bolts out of lower strut slide the spacer in re assemble with the included grade 8 bolts presto your one inch taller in front 25 dollar deal
summit engineering
Well guys I finally pulled the trigger and went with the RC 2.5" for my truck. I have a 2014 6.2 High Country in Tungsten metallic. I looked through all the posts and didn't see any high country's leveled with the stock wheels. I was a little worried about the look with the stock tires but I love it. The truck will get some bfg KO2's when they come out with the size I want, but for now stockers will do. The truck seems to ride just a tad bit stiffer than stock and when I say a tad that is with me really looking for a ride difference. Wound up with 3/4 of an inch higher in the rear and it sits perfectly level with the Ranger behind the truck. All in all I was definitely pleased. Did the work myself and had it done in just over 3 hours and was quite simple to do. Hopefully now there will be some pictures of a leveled tungsten metallic high country for someone else to see if they have the same truck and have plans to do the same thing. Sorry the truck is on an incline in the driveway.
Edited by usafwern05
I like the stance. If you get the chance post some pics on level ground, I want to do something with mine. I have the same truck except White Diamond and a short box.
That's good to know Husker, thanks.
Does anyone know if I could run 295/70r17 tires on a 17x8.5" wheel with 0mm offset? I have a 2" level. A guy on GMFS is running that with a slightly different offset and says he does not rub. I just find it hard to believe.
Thanks for the help.
Wondering the same thing myself. Hoping to push it with 295/70 17 or 285/75 17. Haven't been able to find anyone with that set up. Dealership said they put together several with 285/70 17 with level kit and no rub. I may go that route if I can't find anything on the larger sizes.
Well after some help from the kind folks here and some research I took the leap for a ReadyLift 2.25 for my 2014 Silverado 2wt standard cab . Have a appointment next week for the install at my local Chevy dealer and I'm pretty excited and can't wait . I must say I'm a little nervous since I love the way it rides now although ReadyLift guarantees no change in ride quality also my local dealer said it will not void or change my warranty. Anyone running this kit with a similar truck as mine that's running this ReadyLift 2.25 on there truck that could give me some input and pictures would be great . I scanned threw every page on this thread and haven't seen one but might of missed it .
Also was curious if those with 2 to 2 1/2 inch leveler kits feel the need or had to adjust there head lights down for better visibility and to not blind on coming traffic ?
Edited by TheFactor
I don't have the Readylift kit but anytime that you make adjustments to your suspension or ride height your headlights will need to adjusted. If you leave them as they are then they will be in every other driver's eyes.
That's what I figured , guess I'll have to find a nice flat area and a wall . Anyone know the distance you should adjust them at and what height ?
Sent from my iPhone 6 using Tapatalk
Will do. I have the day off tomorrow so I'll try to get a few and post them up. May have the boat behind it though, depends on how cold it is in the morning and if the rain holds off.
