I contacted my dealer regarding the catch can voiding my warranty and they told me that it would not void my warranty if I install the catch can :)
Sorry off topic but where did u get that grill is oem or aftermarket and what was the price on it looks nice
I have a present waiting for me from RX performance. Gonna see if I can get it installed tonight.
Question though. On my 5.3L, which port goes to which opening on the can?
Never mind, found an earlier post, so basically the hose from under the throttle body with go into the center hole on the can. And the hose on the driver side cover will go to the offset hole on the can.
Edited by fondupot
I can feel a buzzy feeling in the throttle at certain RPM's after I installed the RX. Let me know if you notice it to. I also did the throttle peddle flex mod too...but the buzz in the peddle was there before the mod.
RT
Ordered an Elite can which should be here tomorrow for the wife's Acadia but she'd had enough of the milkshake issues and traded it in today for a Nissan. Looks like I get a can for my 14 Silverado now. I'd have to say I'm happy with this outcome. The wife's happy again and I get the added protection on my truck. Hopefully I'll have time to get it installed in the next few days.
Edited by mjj
RT
I could feel a vibration after installing my RX can also. I followed Newm's idea on page 24 and installed some rubber radiator hose pieces on each side of the mount and that took most of the vibration away. It was noticeable in the pedals at lower RPM's on the highway. http://www.gm-trucks.com/forums/topic/154204-oil-catch-can/page-24 I still have a slight vibration I can feel in the floor board at highway speed, but I attribute that to tires needing a balancing now.
RT
yea there was a post earlier in this thread about having the RX can mounted to the brake booster. The leverage from the can gets amplified through the brake booster and you feel it in the pedals. Look back a bit in the thread and see. One guy used some tubing cut in half mounted in between the can and the bracket to help the vibration.
RT
HI 07Softail,
I installed an ADD W1 can and had a fairly loud suction sound under the hood and a buzzing sound in the cab when taking off slowly could even hear the buzzing over the trans whine in first gear. I took my can off for now will think it over some more.
Edited by southern_sierra
RT
The rubber helps but doesn't seem to totally eliminate the vibs on mine either. Close but not completely. I need to experiment with some other way maybe but it hasn't bothered me enough yet.....or just move the can.
PM sent
Yep you have it routed correctly.
RT
I felt the buzz in my pedal too after installing the catch can. As fondupot said it's from the can being mounted to the break booster and the interior of the can shakes/rattles as the gasses pass through it and this get's transmitted through the break booster to the fire wall and down to the accelerator pedal. I will say after about a 1,000 miles the vibration settled down though. I'm assuming it's from the interior parts of the can, most likely the filter media, getting some oil on it and dampening the shaking around that is taking place on the inside. It's still there, but not as bad. I can live with it and I'm happy with the results of the can so it doesn't bother me. Especially since it doesn't happen at cruising RPM's, just under light acceleration.
I am going to put some 1/4-20 rubber isolators on the bracket and cut some rubber hose and install between the booster and bracket and call it good. Thanks Guys.
EDIT: I installed the 2 rubber isolators and a 1"x 1"x 1/8" piece of rubber between the bracket and booster and the buzzy throttle is gone.
Edited by 07Softail
I read somewhere that Toyota addresses the valve buildup issues by having a special combination port injection/direct injection engine design. Leave it to the Japanese to figure out something better.....as always. Can anyone confirm this? I'm having a difficult time finding information on the internet but I'm also at work and can't really look into it right now.
Yes Toyota calls it D4-S. I think only a few of their engines are using it. I read that the new Tacoma will have it on a 3.5L V6 that is replacing the 4.0L V6 they have used for a long time.
Ordered the mishimoto oil catch can. The non baffled one. I assume I can just out some steel wool in it for the condensate.
How difficult are these to install? I've installed a cold air intake on my '99 once but that's about my extent for truck mechanic'ing ability.
    contrabombarde
    contrabombarde
  • Who's Online   1 Member, 0 Anonymous, 701 Guests (See full list)
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
    • No, we trade them like pokeman cards.
