What is the AN size on the RX can.... I'm wanting to do the Dual exit mod. I'm guessing -6 but not sure
RT
When I did the upgrade on my RX can I used a 3/8" drill bit with a 1/4" NPT tap. Hopefully that helps you.
For GM applications 3/8" id hose, or -8 AN lines will work with the AN style clamps.
Ford takes mainly 1/2" or a -10 braided AN line on most.
So a -8 to 1/4 pipe nipple and a -8 90 degree 3/8 barbed fitting correct. I'm using standard 3/8 rubber hose and want to get the same size 90 degree fitting and straight fitting as the original ones. -8 sounds too large to me
RT
Edited by 07Softail
-8 is half inch, -6 is 3/8. -10 is 5/8.
Correct, but the AN braided line as far as fitment over a push'lock AN fitting works the next size up. Trying to push the -6 over 3/8" barb is very difficult so the -8 fits slightly snug, and then use a AN clamp end to secure them and so on. The Elite cans come with true AN screw on fittings, so then the -6 would be used, but it is then difficult to fit the barbs into as they are a 3/8" barb. I think most get the push-lock style AN fittings so if wanting to use the braided line, then using the next AN size up makes it easier for the installer (as long as you use the AN clamp ends like these:
http://www.summitracing.com/parts/fra-280208
This makes a nice clean install when used on each end of the braided line at the checkvalves and other fittings.
Thanks!!!
Got my catch can in yesterday. Not a single direction in the box. I told them I wanted to mount it in the spare battery location. So since there's no directions, where does it actually mount? To the bottom of the battery tray? To the battery tie down support?
Edited by knkguillot
I think I used the bolt holding the windshield washer bottle to attach mine.
Sent from my SM-G900W8 using Tapatalk
Well the only place that made since with the bracket they supplied was to bolt it down to the bottom of the battery tray. I'll get pics shortly. Hopefully I did it right.
Here's how it's mounted. Has anyone else mounted it like this? It's bolted down to the bottom of the spare battery tray.
Here's another mounted in that area. The way you have it doesn't leave much room for drainage.
http://www.gm-trucks.com/forums/index.php?/topic/186456-Throttle-Body-Pictures-w/-Elite-Catch-Can-&-Clean-Side-Separator&do=findComment&comment=1798828
Flip the bracket around to attach to the washer bottle. That said I have a piece of 3/8" stainless tubing off the valve on mine thay drains over past the pcm so I can easily get a pop bottle under it
You'll want to mount it like this?
    • Thanks for response. Leak was right under drivers seat or thereabout.   Had checked by other mechanics and have read other information.   The solution can be a tad complicated and replacing multiple parts And with some.  The issue was still the same.   The brakes do work.   Just that the pedal is softer and goes further down.  But the brakes do work.
    • Breaking News!    I'm going to tell you that I'm going to tell you.  Then I'm going to tell you what I'm going to tell you.  Then I'm going to tell you.  Then I'm going to tell you what I told  you.  Then I'm going to tell you what I'm about to tell you on the other side of the break.  Then we're going to break. Then I'm not going to tell you what I told you I was going to tell you.  But I'll tell you something else that is Breaking News just coming to the desk that everyone reported on yesterday.  Then I'll tease a human interest telling I'll get to on the other side of a larger break. Then I'll tell you one item in 20 seconds and go back to an even longer break. Longest break of the night.  Then I'll tell you a fluff piece that takes 10 seconds and sign off into a three minute break while you wait for the next 30 minutes of rinse and repeat on the local news.    In al you'll get about 12 minutes of something, 5 minutes of which is worth hearing in a 30 minute show and 18 minutes of advertising at a sound level twice as loud as the news.    Of course you can switch to cable news and hear 12 different people tell the same four stories in much the same format as the Network News for 20 hours of which the majority will be advertising.  And four hours of late night Specials about things you wonder why you stayed up to listen to. Half of which will be repeats.....   OR you can go for a drive
    • Did you ever figure this out? My 2022 Trail Boss, and now my 2026 LT did this from time to time.  I believe it was more connected to Android Auto and my phone being the cause. Maybe try going for a drive, sans cell phone.... and see if it happens?
    • I have a 2026 Silverado LT, the non bose as well.  Upgrading the door speakers is pretty straightforward. You could honestly go to walmart, or Auto Zone/ O Reilly and get a set of 6x9s for the front, and 6.5s for the rear. You do also have to get some adapters for each, but they are like $10 a pair on Amazon. Then some plug and play harnesses that are about $10 a pair on Amazon as well.  And I would also suggest a 10 pack of the Amazon Basics sound deadening. Slap that all around the speakers and on the open metal of the inside of the door. And your golden.   I am currently doing this with my Silverado. Although I am having a bit of trouble because I am snooby I guess and bought some Alpine S2 S69c's which are 2 way components and I am having to wire from the door up to the dash....  Having never installed speakers before, its taking me just a bit to get everything correct. But if you dont buy expensive component speakers, and just some $40-$50 door speakers. You will DRASTICALLY improve the sound over these stock paper cone junk speakers. I thought my Silverado had an issue with the radio/ sound for a while.  Come to find out.  The stock speakers are just THAT SH*TTY   I cannot wait to have some decent sound in the truck   What did you end up doing?
    • Its all automatic based on yaw sensor data.  If enough incline is detected, it engages.   My recommendation though would be to disengage it before driving off and not let it auto disengage by touching the gas pedal.  The HD trucks use the same setup as prior years, the drum in hat park brake.  But now with an electric actuator.  If you drive off repeatedly over time, it can torque the park brake shoes and can also prematurely wear them out.           Electric console shift will set the park brake on flat ground too.  Pretty sure they've got it programmed to activate every time.
