TPS reading backwards
I had a few tires reading a few pounds low so I put some air in them and found that the fronts are reading as the back and vise versa. Dealer did a tire rotation and balance, do they need to reprogram after?
Their positions need to be reprogrammed. I suggest buying the $50 tool to do it yourself
ya take it back and make them adjust tire pressures and DO IT RIGHT !!!!
I guess the only one out for the 2014 is expensive as all hell. One will be available soon
Sent from my Samsung Galaxy S4 using Tapatalk 4
a) make them do it right
b) i know with the 7 to 13 trucks you could push 2 buttons on the fob or do something with the 4 ways to make it go into learning mode then just lea a little air out of each tire starting with the LF working clock wise and it would pick it up
It's u hold the lock and unlock on fob it will beep twice and then the tool will reset them...that is how the 2007-2013 were that way.... Any goodyear , michelin firestone dealers can reset as well no biggie
The manual calibration stopped before 2013, it may have even been 2011.
    • The curb weight on a 1 ton crew cab long bed is around 7k lbs.  Now, I don't know where you went to school but 9k is not more than 2x 7k lbs. More than 2x 7k lbs would be 14k+.   With that said, obviously yes you're going to feel a 9k lb trailer when slowing down.  I already said, when accelerating.  When changing lanes?  No.  But if you look at the context of what was quoted, the original person said, "after a mile or two..." which means that would be after the accelerating portion and you're driving a generally steady pace.  Please do learn to read and comprehend.
    • "Life is getting back to normal."    I'm driving again and all new joints are operating as expected for this stage of recovery.   My most recent joint replacement still requires a lot of attention but experience has taught me that time will quiet the remaining pain.  I joked with my surgeon that another joint replacement would take my mind off my most recent surgery and he responded by saying the next will be a hip!  There are no plans for another surgery but, unlike me, I don't think he was joking!  I certainly wouldn't refuse further replacement  if required but hope to spend time out of the "post-op"  period.  I can't stress enough that if you have been recommended for total hip, knee or shoulder replacement that you welcome the offer.  Post-op "recovery" may sound daunting and painful, however, this is far better than the insidious erosion of mobility you are currently experiencing.  Imagine what it would feel like to wake up most mornings feeling better and more mobile than you did the previous day!  Prior to my first surgery in June 2025, even getting out of bed was becoming a formidable task.  Since the day after my first surgery, I get out of bed everyday easily and unassisted.  Making the switch to feeling a little better each day rather than a little worse, is hugely motivating!
