15 crew! Black on black and first brand new truck. 15% front tint and 5% rears. 2.5" RC leveling kit. Have a few more things I'd like to do, but only had it for a month or so!
You have the RC 2.5" level on with stock rims and tires on in that picture right? Can you post some more. I have the exact truck and want that level, but I didn't know if it looks real funny without bigger tires.
I don't think it looks horrible, but I do plan to get bigger tires (whole reason for the level).
2" Rough Country Level. Stock wheels and 275/55/20 tires.
  • Like 4
The front is an RC 2" but that's coming off soon and putting the pro comp adjustable struts on... Rear is stock but with the pro comp shocks.
Tires are 33x12.50r18.. Wheels are 18x9 with 0 offset
Any rubbing at all or did you have to cut the fenders? I'm looking to do this same setup on mine.
NO Rubbing and no trimming at all with a 2" front kit, there is still a lot of space.
Edited by nando87
Yes, stock 18s with 2.5 RC in the front. Love that it leveled my truck damn near perfect. I have a set of 20x10 that will go on once i get tires, but still looks great in the mean time!
Huge fan of those wheels. Hard to find those for sale !
Thats how it all begins! Colormatching Hell! BTW those OEM wheels weigh like a ton! My Black Rhinos are noticebly lighter than my SEY's, and feel better on the road. When my truck was being built, it was supposed to have that SEV wheel package. They ran out for quite a while and it was either wait until they were back in stock or go with the SEY's. I was changing them anyways, but after handling the OEM 22's I realized I wanted something lighter for sure.
Got some new tires a couple of days ago.
BF Goodrich AT KO 285/65/R18
I absolutely LOVE what they've done to change my pickup
Here's a before and after.
Next up is a level and some breathing treatments (Exhaust and Airraid MIT)
Then a Topper
Looks soo much better with the BFGs.
2015 GMC Sierra All Terrain, Stone Blue Metallic.
285/65/18 BFG KO2's
18" Fuel Assault's, +18 offset
2" Ready Lift Level.
Love the look of this truck, but I'm pretty angry at myself for not getting 305's and a more negative wheel offset to give it a more aggressive look. Got 1000km on her in since I picked it up yesterday and so far there is a minor vibration at a speed of about 120km/hr. Fuel mileage so far has not been very good for me. (15 mpg all highway). I know the BFG's don't help, but I was still expecting much better.
Another issue I'm having is that the speakers periodically crack at anything above half volume. Not acceptable for the so called "Bose Premium sound."
Also a little irritated with the throttle lag, and the touchscreen lag. I had a short race against an ecoboost on my way home and got absolutely smoked.
Besides for that, great truck so far. I absolutely love this colour, glad I held out for it!
  • Like 6
Truck looks great!
Sent from Tapatalk App - Samsung S6
Thank you. When I saw them I had to get em. Sold my 22" 5 spoke ones that came with the truck and bought these new. They look so much better IMO.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
    • Just don't turn the steering wheel as much?
    • Rockauto bud. I pass local stores for parts.   Findya something online.
