Here's my 2015 HD front end on 26x9 and 26x12s intros lowered 6/9 waiting on 2 piece drive shaft and then getting a Magnuson supercharger
Very nice! Excellent mod! I take it you had to tub the bed?
im (40) grew up during the boyd days and still have a love for sport trucks...
just not practical for me and what i use my truck for! are you in houston? i swear every built sport truck i see is out of houston...why the huge scene down there?
Actually I'm from SoCal and yes Houston has a huge sport truck scene but CA is growing quickly
Yes sir tubbed front and back and shaved a little off the firewall
Love the pics. Am I one of the few who check this almost daily to see the cool pics? :)
nope me too lol faithfully every day. more than facebook actually haha :cheers:
I'm a wheel and tire nut, I check all the time. I have the email notifications setup so I know when there is a new post. Even if it's you chatty Kathys.
Sent from Tapatalk App - Samsung S6
Those are some sweet ass winter wheels
Haha... yeah, last winter I had the 20" Tahoe wheels on the truck. Just didn't have enough "wow" factor for me! :lol: I'm a mess. :nonod:
post-143080-0-45454800-1444887922_thumb.
Holy sh!t. That is badass.
Edited by Luster
9CB9267B-E791-479D-ADA1-3BD78E81DD93_zps
Thats ma boat Lt Dan :rollin:
Edited by Mike1220
  • Like 8
Mike I haven't seen your truck in a while... You've been busy! Looks awesome man.
Sent from my Nexus 6 using Tapatalk
Thanks man :) I have been busy balancing school, life, family, truck and friends, not necessarily in that order of course haha. Follow me on instagram if you have it, I post on there more often now that I made a page for the truck haha. Project_white_diamond_tri. I hope to get a few things done to the truck around Christmas
068E40D4-93AB-4134-837E-4FB0874ECD7E_zps
A4C524AC-86DB-447A-A56C-D67DB775F379_zps
F045A0B9-309F-4413-BA56-4AB097962244_zps
This is also part of what's been keeping me busy [emoji41]
Edited by Mike1220
Hello everyone!
Just picked this up a couple weeks ago and wanted to show it off.
2015 Silverado LS 4x4 5.3L
Removed the 4x4 sticker on bed, all Silverado badges, and the huge bowtie on the tailgate.
Also added an Extang tonneau, and tinted the front windows 20%. Not pictured, but recently installed the GM rear fender liners.
I'd like to do a levelling kit and some more aggressive 18" wheels/tires instead of the 20" that was factory.
Here's a pic -
Edited by Ian-NH
    Randy Ginoza
    Randy Ginoza
  • Who's Online   4 Members, 0 Anonymous, 2,136 Guests (See full list)
    • Paid $2.72 for E85 today.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
