I tried wrapping the chrome part of the grill but made some bad cuts and just ended up removing it. I will be trying this again soon. 8c7458b1c4cae1ee76c02a0e1ef70a43.jpg
Another pic with new wheels...
  • Like 10
New and old 2004 Silverado. Amazing how much changed in 10 years.
I love this picture and have seen this several times. I had a very similar truck to your older one. Mine was a 2004 metallic gray the same as yours.
I found a black 2014 GMC now but would have rather had the iridium like you got.
Edited by OmahaBen
2014 Silverado 2WT CC Summit White 4.3L V6
DROPKICK Edition
IG: jorge_dropkick_rangel
Great looking rig! Those are Anzo UBars correct? I have them on my truck...love em!
Thank you and Yes sir, you will love them more if you do the amber delete mod so the u bar can be used in its own.
DROPKICK Edition
Very nice wheels [emoji106]
I second that! :thumbs:
Thanks guys... I've always liked GM Accessory wheels. (I kept the chromies. They'll go back on in the spring... well..... maybe) :fingersx:
NOOOOOOOOOOOOO!!! The Chrome ones are a lot nicer IMO... BUt I am a chrome guy... Don't get me wrong though, your winter wheels are very nice...
I agree... the 22" chrome wheels get lots of looks. I like chrome also... but sometimes I go to the "Dark Side". :nonod::dunno:
Added the Zone 1.5 BL over the weekend
looks good! is the body lift a huge task?
    AidenVorpagel
    AidenVorpagel
  • Who's Online   3 Members, 0 Anonymous, 1,307 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
