Nice fall day!
Looks good!!! What size level/lift do you have and what size tires???
I need to know all of this as well, love the look!
Thanks I have the 2.5rc+1.5zone body lift the tires are cooper st maxx 295/70r18
What kind of mount did you use in the tow hook openings?!
The light is the mount. Just had to drill a hole up top and bolt it up. Had to add a thin piece of Al. flat bar on top on the inside of the tow hook area to keep the light from flexing.
Mictuning 4.5" lights from Amazon...spot beam pattern, adds alittle extra light downroad with my highbeams.
Nice truck and Headlights look good can you post a few more pics of them
I plan on painting mine black eventually but probably leave the reflector orange and maybe painting the black piece around the projector dark grey for some contrast. Did you bake or cut them open?
Also, you have to cut the tabs off when disassembling the the guts of the headlights to paint right? How did you put it all back together, jb weld or something
I'll try and post some pics later when I get home.
I baked them to get em open, the hardest part is cleaning the channel out of the old permaseal, stuff is tuff!
I think the only tabs I had to grind off were for the turn signal reflectors, and I used a little jb weld to set em back.
I just ordered clear reflectors from Clearz with switchback bulbs and outline halos from led concepts. Probably paint the inside near the projector silver for some contrast. Too much black now, everyone asks if I have light covers on...
This is my 2015 Silverado 1500, I just recently got a light bar put on it and will put a picture of that up soon! Comments welcome, thank you!post-149827-0-62717800-1446075025_thumb.jpeg
Edited by GChev15
  • Like 4
Not a real big fan of Fuel wheels, but the dark tint looks great with your truck color! Truck looks real clean...
Def. post up some pics of your lightbar, probably get me one soon too.
Here ya go...
It's truck month. I am new here but not to trucks... I sure love this one, it's just an LS but still pretty nice. The 5.3L will be breathing better by Saturday morning - new exhaust. Photo taken in Twentynine Palms.
Edited by OC Chevy
Liking your pic....what kinda exhaust are you getting?
Bros 2016 Silverado getting align after 4/7 drop
Nice truck any more pics
Sent from my SM-G900V using Tapatalk
2014 Silverado 2WT CC Summit White 4.3L V6
DROPKICK Edition
IG: jorge_dropkick_rangel
Sweet truck Jorge!
What's that grill guard brand?
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
