attachicon.gif20151124_135818.jpgtime for a swap
I think your 14/15 looks much better than the 16. Just my opinion
I love your pictures you take, what camera do you use and how do you get those great quality shots.
Sent from my SM-G925V using Tapatalk
I don't know what that mean. Lol
Moving the handle to the inside of the tailgate.
Fat fingered, and shot from the hip.
Oooh......shaving the handle. No, I like the position of the camera. Believe it or not, I tow with it a lot and it's so handy when loading a trailer.
Would love to see pics of your rig towing. :pimp:
Just bought this one and haven't done anything to it other than tint the windows and remove the bowtie from the tailgate. Traded an '05 Sierra and am loving it so far.
Thanks man. I use a Canon T6i. & honestly I'm not even close to an expert, I just mess with the settings on the camera and take random pictures. So far that method has worked for me.
Wow it's working for you then I would say, those are some great shots. I have a Nixon d5100 dslr I need to mess around and see what I can get. What settings do you change and also what do you do for the steel wool pictures
New in here, just into a Silverado. Came over from a Tacoma/Tacomaworld. Nice trucks in here. Looking forward to a few changes to my own rig. Hopefully soon.
  • Like 5
