Picked it up Friday. Step bars taken off - tonneau to go on this weekend.
Factory Spec + Dealer Mods:
2016 SLT CC SB
5.3L
8spd
3.42
Nav/Sun
LEDs
Spray in Bed Liner GMC
Slider Rr Wdw
Apple Car Play
Wireless Charging
2.5 RC Level w/2" Blk
33x12.50R22 Toyo Open Country MT
Tint
To do:
K&N 63 Series
Tune
Power steps or 4" Matte Black OEM Tube steps
Wash every weekend because, well shit... its black.
Some immediate feedback:
the 16 over the 14 is much more impressive than I thought. Toyo MTs and a lift - REALLY make these trucks. Driving it around, I feel like I'm in my Camaro and its 2011.
Very nice!
Rogey89 good looking truck! Do the power step.
Just got done doing the color match on grille, headlights, and bow tie
How exactly did you color match the grill. I'm considering doing it on my slate grey 2015 LT.
Dealer just called yesterday letting me know it had arrived and then later sent me this.... cant wait to go get it.
Hasn't been detailed yet pretty much fresh off the truck but still looking good.
Now to find some take off 20's from a GMC and it'll be looking even better.
The overwhelming census is NO to the stripes in Ruby and DOABLE to the Center Caps... One fella wanted to see it in Black, so here are a few more tries...
attachicon.gifWHEEL CENTER CAP RUBY.JPGattachicon.gifCENTER CAP RUBY.JPGattachicon.gifWHEEL BLACK.JPGattachicon.gifBLACK BOTH WHEELS.JPGattachicon.gifCENTER CAP BLACK.JPGattachicon.gifWHEEL CENTER CAP BLACK.JPG
Black all the way now... I like both stripes and caps. I agree the red isn't a perfect match so...
Sent from my Nexus 6 using Tapatalk
Lol at that quote, I know exactly what your talking about, I miss those days in my Camaro
Edited by 1badtie
One from the front
how easy was it to install those rigid led fogs?
silverado1
my 2016 Silverado 1500 LT, 5.3L Ecotech. Autumn Bronze Metallic.
Not sure, had the local truck shop install them for me. But, I do know there is some cutting required
:ninja:
Cool hood! RK Sport??
Edited by cato
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
    • Just don't turn the steering wheel as much?
