Steve, how do you like your Sierra?   Any favorite features?   Thanks.
I absolutely love it. I can't say I have a favourite feature, the truck has functioned flawlessly however. Are you thinking about getting one?
Sent from my SM-G930W8 using Tapatalk
On 11/2/2017 at 10:21 PM, 2k05Z71 said:
2017 crimson red Denali Ultimate.  Need the 8 speed tranny tuned to unlesh the 6.2!!!
Don, how do you like your Sierra?  What do you like about it?   Thanks. Steve
On 10/22/2017 at 7:11 PM, DQDenali said:
My 2017 GMC Sierra Denali Ultimate & my wife’s 2017 GMC Yukon Denali.
How do you folks like your GMCs?   Any favorite features?  Thanks.
Oops, I think I sent my message to the wrong person.  It was intended to go to 2k05Z71 (a "Steve").  Sorry about that.  Glad you like your GMC, though!
On 1/7/2018 at 8:30 AM, VTBulldog said:
Here is your chrome delete!
And here it is with black wheels.....
Now it looks like everyone else's "black out everything" truck.    IMO, looks great as is....I would leave every bit of that chrome on there.
New here. My new 2018 z71 ltz midnight edition with the 6.2. Coming from a 08 2500hd duramax that was pushing 700hp to the wheels. Just got tint done today on the new truck.
I would love to level but would need airbags forsure. When I hook my trailer up I’m dam near level stock. I guess that’s why they give them rake lol.
Nice setup! That is exactly why they give trucks rake stock, and that is why it is usually pretty easy to spot who bought one for the looks/image and who bought one to use...
Tyler
Welcome - your truck look's like mine - DIRTY .
    Randy Ginoza
    Randy Ginoza
  • Who's Online   3 Members, 0 Anonymous, 2,122 Guests (See full list)
    • Paid $2.72 for E85 today.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
