Never been a Dodge fan but I thought the ram 1500 was supposed to have a more plush ride than the GM twins. Not the case?
I came from a ‘14 1500 Ecodiesel before my ‘17 Denali, and I do miss the smooth ride of the Ram. I think the interior was better in the Ram too, but that’s all I miss. Things would have to take a serious turn for me to leave GMC now [emoji106]
Edit: I would probably be happy with a Raptor too if I’m honest ?
On 4/19/2018 at 4:06 PM, Slabsides45 said:
I did the same with my 2015 Crew, same wheels with some Toyo Open Country 34.6" tires.  Really like the look of those wheels on my Brownstone 4x4.
Do they look different on 2wd brownstones?
Tyler
Tyler
Yes, they sit closer to the ground and smell like Geritol and Ben Gay.
Here's my new to me '14.  Will have a 2.5"/3" level and wheels and tires (33x12.5) some time this year.
2018 Silverado LT Double Cab got 20" wheels.
On 4/22/2018 at 11:39 PM, jeffwilson1210 said:
2.5 rc level 3” block, 275/70/18 falken wildapeak at3w, edge cts2 so far, just ordered 20x10 fuel Mavericks w 275/55/20 Toyo at’s will update soon
Before you swap tires, can you take some measurements for me?   I don't typically like a 275/70 because they are so narrow, but those look good.
What is the tread width (edge to edge)?
What is the section width (bulge to bulge)?
Total mounted height?
Also, a pic from the back and front to see the width of the tire.
Thank you!
Thank you!
Damn bro I just put my truck in the shop this morning for the new wheel setup. Sorry!!
But I was skeptical as well w it being so narrow, but when I got them mounted I was pretty happy
Did you get rid of the rims and tires already?    measurements mounted but not on the truck would be OK too.
I don't think you're gonna like the ride of those new 20s!!
I’m picking it up tomorrow after work I will give you the measurements then. Don’t say that haha we’ll see though.
20180414_140247.thumb.jpg.0296751e020cf436428d10d16aeb59ae.jpgnew around here thought  I would show of my 2017 rclb she runs 35 12.5 17 with just a 2 inch leveling the front
Nice ride!  What tires are those?  AT or MT?
Anything will fit with enough trimming! How much did you have to do?
    Randy Ginoza
    Randy Ginoza
  • Who's Online   3 Members, 0 Anonymous, 2,122 Guests (See full list)
    • Paid $2.72 for E85 today.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
