On 6/16/2018 at 8:02 PM, Rock1500 said:
What size tires and rims are you running?  Also what is the brand of tires?
35x12.50x20 inch rims. Nitto Grapplers G2.
On 6/14/2018 at 6:10 AM, diegosaurus said:
Nice truck!  I had been searching for a pic w/ ranchhand bumper too.
Thank you! Let me know if you want any other pictures!
On 6/14/2018 at 6:37 AM, TXGREEK said:
I was looking into one of those Ranch Hands as well but the manager at the dealership told me that they’re to heavy for the frame on half tons causing damage so I’m now looking into other setup
The manager didn't really know what he was talking about then, on the 14+ Sierra/Silverados Ranch Hand made them a lot lighter without losing the tensile strength of the steel. I will say there have been reports of accidents causing damage to the frame that have been linked to a heavy front end impact that someone tried to blame on Ranch Hand for a quick payout, but the Ranch Hands were not in fact responsible for the damage to the frame...the heavy front end impact was. Who would've thunk it? :rolleyes:
On 6/21/2018 at 8:17 AM, goeb34 said:
Guy i follow on instagram had a 3” level with 35s and 22x9s on a 2017 sierra
I am running a 4" Rough Country and I run 35x12.50x20 w/ no rubbing at all. My wheel wells have been trimmed heavily but it was not to cut down on rubbing but to match the line of my Ranch Hand front bumper.
On 6/21/2018 at 8:43 AM, jimmyboy8301 said:
And he definitely trimmed and probably cut metal......
2017 Chevy Silverado LTZ Z71 6.2L
4.5" Zone w/ Bilstein and Fox
22x10 American Force Grips
33x12.5 Nitto Ridge Grapplers
Instagram @wildchevys
Hey Jimmy! Not to say you're wrong or anything but I do run a 4" Rough Country w/ 35's and I get no rubbing at all. I admitted to cutting the wheel well for my Ranch Hand but even before I did that I had minimal rubbing at full turn and not a single inch, or millimeter for that fact of steel has been cut on my truck. I did all the work myself so I can assure you of that.
Hope I helped! Have a great weekend!
You’re also talking about a 3” vs a 4” which makes a big difference
Looks good but You’d need more than a 4” lift to run 35’s, 6” and you may need to trim the valance.
You are absolutely correct! I actually quoted the wrong post, this was the post I was meaning to refer to. My apologies, hope I didn't cause you any discomfort!
Meh just the need for more beer
I absolutely agree with you there! :cheers:
No, I wasn’t talking about accidents causing damage. I was talking about the mounting areas, should’ve elaborated. Apparently, now this was years ago, only had heavy steel then, excessive stress fractures found on half tons located at the front mounting caused by these type of heavy steel front bumpers. Today it seems you’ve got a large variety of aluminum to choose from
3 hours ago, 14 Silvy said:
Specs?
2018 with 6” BDS lift
22x12 -44 fuel two piece renegades
35-12.5-22 Fury MTs
Edited by Jrhoads88
    tararebecca
    tararebecca
  • Who's Online   1 Member, 0 Anonymous, 586 Guests (See full list)
    • I agree, simplicity and reliability matter more as vehicles get more complicated. A V8 work truck option with fewer electronic features and a stronger warranty would definitely appeal to a lot of buyers who use their trucks for real work. Customizing it with trusted outfitters is often the best way to get exactly what you need.webcrimsNY
    • I’ve heard similar complaints from newer vehicles where the factory “premium” systems don’t always live up to expectations. A good installer should be able to improve the sound without turning it into a bass-heavy setup. I’d look into upgrading the front speakers, adding a quality DSP amplifier, and possibly improving sound deadening first—those changes usually make a much bigger difference than just adding a subwoofer. Hopefully someone local can recommend a reputable installer in the Las Vegas/St. George area.
    • Do you remember that Harley Davidson was more successful (solvent) when it produced about 60% of the market demand (by design) and forced wait times of up to three years? Even when your turn came around it was, "Take what we are giving you or move to the back of the line and start over". HUGE markup's were 'normalized' and dealer killed. 40% markup and no floor plan? What's not to love? Greed will kill them yet. They have surplus production and customer base is tanking. And still they think nosebleed pricing will work.
