10 hours ago, jgraves13 said:
Looks great. More info on truck?
Thanks, It's just a 3" maxtrac level sitting on Nitto Trail Grapplers 285/65/18.  The wheels are Fuel trophy D552 18x9.  The running boards are GoRhino RB20's.  That's pretty much it.  I would like to change out the wheels for bronze wheels, change out the exhaust, and hopefully the 4" BDS lift with fox coilovers.
Edited by shadrickjm
Picked up a 2015 Denali, and absolutely love it!
I did get a level kit in, which through of the magneride, so it's currently getting that reset along with the alignment today.
Edited by FREEZE451
14 hours ago, Aaron1085 said:
I run a Morimoto 35w kit. Remind me how to lower the headlights again please?
1) find level ground, i used my driveway and garage door and parked about 20 feet away
2) Aim truck at garage door and turn on lights, works best at night or dusk
3) with painters tape, mark the center of each headlight beam on your garage door
4) open hood and right around each headlight are a white plastic "screw", philips head
5) Turn them in the direction to lower the beam
6) I lowered my beam by about 2inch from the tape mark
7) Youre Done
Finally got my wheels and tires on it. Damn she looks so much better. 13e71d2e0eaf571b30e5ea00af134673.heic3f5411993a6f980651d025a546a63f45.heic454396e3670703c809d0985490259152.heic
I’m so happy I decided 0 offset it ended up exactly how I wanted it too.
  • Like 3
New to the forum. Here's my 2017 Sierra 1500 All Terrain in Crimson Red Tintcoat. You can follow my Instagram @StockRedSierra for more pictures and updates. Just installed a sPOD HD and I have a 30" light bar coming next week to put behind the grill after I delete the active grille shutters. I will be starting a build thread soon for it as well!
  • Like 3
2015 SLT w/ 2" RC leveling kit, 285/70-17 KO2s on 17x9 -6 Pro Comps.  Recently got rid of all the awful chrome trim and badges.
80-_img_2218_e5853e5f6a94e36608f0f7f4897
80-_img_2220_3b6ea84b262fc17e02086e8b10e
80-_img_2222_8be7f0d772910ac06df4ea8fa1a
80-_img_2226_3163ae1c299ecb3341e0c064795
  • Like 3
Looks good! I recognize that pull off near the Union St. bridge.
Just picked up my GMC truck!  Love this thing.  '18 Denali in white frost.  I have never owned a GM truck before, so I am leaning heavily on all of you experienced forum members for advice and help.  I am contemplating a lift, or at least a level.  After seeing the black widow package that SPC offers, I am maybe leaning toward the 6" lift but don't want to void my warranty, so maybe the level is the way to go for now?  How big of a tire can I go with a level kit?
Hmmmm....sorry my pics are crooked.
Edited by paulny
On 6/13/2018 at 12:37 PM, TyGriff13 said:
Here's a side shot for ya! N-Fab running boards.
What size tires and rims are you running?  Also what is the brand of tires?
Looks great! Take it slow and easy, is that the 6.2 or 5.3?
Upgraded the 2017 Sierra elevation to the 2018 Sierra All Terrain with a 4.5” Zone Lift
  • Like 4
It’s the 6.2, and thanks for the kind words.  I see a corsa exhaust and maybe a whipple SC in my future.  Although, it’s plenty fast now.  After seeing pics of the ‘19 Denali, I knew i had to have an ‘18.
This Red pops in the sun. Washed and waxed the truck this morning before the heat showed up. Debadged the tailgate, but it's too hot now to do the doors. Will get them next time.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
