14 hours ago, jgraves13 said:
Sitting in the parking structure at work like it does every day
Great looking truck!
Looks nice!!! What kind of lift do you have?
Sitting at the seawall the other day
Sent from my SM-N950U using Tapatalk
On 7/17/2018 at 3:26 PM, nmyron said:
Thought I would put up a new post. A few weeks back I took my 17 Elevation to the dealership I purchased from, just to take a look around. They made me a great offer on a buyback to get me into a demo '17 SLE. More favorable financing terms, much lower payment, and I walked out the door with 12k more truck than I drove in with.
Ended up with this here truck, with a much nicer looking interior. I got a factory spray in with this deal. Too bad I had just shelled out to have the full Ziebart treatment done on my prior ride the months prior to getting the swap out :(
At first, was a little unhappy with the chromed bumpers. But after a couple thousand miles, and cleaning bug junk off these, I'm a little happier to be honest. They're a lot easier to keep clean. Otherwise, I got the rest of the same gear I installed on the prior. Some good Star Armor steps from Tyger Auto, the same upgraded LED backup/cargo upgrades, did the one-wire hack to get the reverse and cargo lamps to light up with one another. Need to order some ventvisors to keep the rain out when the windows are cracked on the highway, and will probably take this one down to my local Ziebart shop to have it done up as well. Did the full bugflector on this truck, I had the Hoodflector on the last one, but it's narrower shape and lower slope ended up with me catching a few rocks up high on the glass. The bugflector is a bit more wide/tall, and has a higher angle of attack in relation to the hood, so I'm hoping that will do a better job of deflecting rocks up and away. Also, this go round I did Weathertech No-Drill mudflaps, I didn't want to shoot any screws through steel this time. Even though I did a super-thorough job of rustproofing the holes (several coats of paint over both sides of each hole), I'd rather just not risk rust at all this time.
Myron,
You look like a proud new father!  :D
On 7/15/2018 at 9:59 PM, 28fiend said:
Been lurking here for awhile, just wanted to read and learn before I asked any questions. Traded my 12’ Ram 2500 6.7 for my 17’ SLT. Rides so much nicer.
How are those tires fitting?  Any rubbing or scrubbing issues?
They rubbed a bit on my Husky flaps, so I had to thin this out where they mounted. The rubbing now is on the felt wheel well liner. It’s not even bad, so I haven’t done anything about it. But an easy fix from what I’ve read, zip tie it back some, or cut some of the corner out with a razor blade.
I love the size.
I love the size.
Sounds good.  I was debating between 295/55/20 and 285/60/20.  I'm only doing the 1.8" Bilsteins so they may both end up working.
    RangerRick17
    RangerRick17
  • Who's Online   5 Members, 1 Anonymous, 600 Guests (See full list)
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
