Just now, LTeddy said:
Damn how new are your tires? Mine are the same size and ko2s as well and yours look like they are bigger and fill the wheel well more emoji848.png
Sent from my SM-N950U using Tapatalk
Almost a year to the day old, 17,xxx kms
On 8/10/2018 at 4:39 PM, retodd709 said:
Well that’s awesome! Guess I gotta order one of these, avoid giving trump some money in the process. Is that the fancy one with the retractable light bar? If you feel ambitious sometime, think you could measure how much it sticks up above the cab? (Stupid underground parking)
It sticks up 6" to the top of the lights from the roof.
On 8/9/2018 at 4:43 PM, psu said:
^ What wheels/specs? I like it!
Sorry, been busy with work and life.
I'll get you all that information and more pics later today.
New to the site.  Traded in my 07 classic for this black beauty.  Had to do some upgrades right away.  Matching tint, 2" MotoFab leveling kit, 3" Barricade nerf bars, Gator tonneau cover and of course the 18" moto metal wheels with 285/75R18 Amp pro AT tires.  Next on the list is a cold air intake, exhaust and possible paint protection for the front.
Edited by TravisZ71
On 8/12/2018 at 3:00 AM, Plwtwo said:
Wanting to drop mine back down to stock and pull the read block, and this isn't helping!
I know you have a drop kit, but same concept I am going for.  Looks good!
New to the forum, here is my ride.  2018 Chevy Silverado 1500.  Has 6” BDS lift with 22x12 -44 Axe 2.0’s wrapped in 33x12.5 Nitto Ridge Grapplers.  Has always been my dream to have a truck like this.
  • Like 3
Maybe similar but my 4wd All-terrain is lowered as u pointed out, with a 3/5 drop. But I still have the rear OEM spacer in, altho I was going to remove it, the drive-shaft would have needed to be shortened IMO if I pulled it out. I was afraid of the drive-shaft punching the transmission from suspension travel downward.
2015...35x12.50’s Toyo OC RT,SOTA AWOL 20x10 oh and 6” lift..Should i do 13.50’s next time??
2C546FC4-EA5C-4DE9-9176-DBFB853216FC.thumb.jpeg.704cd415f28174a6b2c3e2d3d922dc59.jpeg32F1B07B-1008-43C8-9C37-F82C3AF2820D.thumb.jpeg.44168cd8938944862a858757e5a0f41b.jpeg
Edited by ChrisFTx
Here is my 2018 Z71 LT All- Star Crew in Graphite that I picked up last week, traded-in my 2016 Collie Z71 Crew and what a total difference in power and space. :)
Edited by captainzombie
Welcome - Look's good
    • Sure, but they do have some affordable options like the Trax, Trailblazer, Envista, and Encore. Some of these have a cheaper base price than the Civic, though the fuel economy isn’t as high. The main problem is that people WANT the highest trim with all the goodies and finance for like 7 years. That’s how ppl “afford” the more expensive vehicles.
    • Holy s**t - not much of a parts thrower you say? You BLASTED that thing with the parts cannon!  You'd have been probably $1,000 ahead if you had just brought it to a competent shop rather than shotgunning a bunch of parts it clearly didn't need.   Just FYI - oil additives are really, REALLY good at ONE thing ... and that's emptying your wallet. They're ALL useless gimmicks.   If that has the L94 or L99, then #7 is an AFM cylinder. I'd suspect a failed lifter in that case.   If you leaned on wiring, sensors, and/or connectors while changing the oil, you'll have to check all that to be sure pins didn't get pulled out, connectors broken, etc.. Old wire loom that was barely adequate when new is certainly brittle by year 19 - make sure wires aren't chaffed and shorting out somewhere where you might have leaned. or supported yourself on it.   If your a mechanic, why didn't you just find out what you were missing and troubleshoot from there??  TIMED spark, fuel PSI / injector pulse, air, compression.  Can't make ANY money going the parts cannon route.
    • LOL! Are you joking?? That wax SUCKS! 100% gimmick made to "look" good.    After just TWO winters I had severe surface rusting in patches over 90% of the frame. Only reason it looks great in the pics is because I SATURATED the frame every single fall with used motor oil for 14 of the 16 years I owned it. Otherwise it would've been sent to the crusher 8 years earlier with the speed it was rusting prior!    I sold that POS 3 years ago. Was a gigantic headache the second it rolled off the showroom floor. Brakes pulsated on the TEST DRIVE. Door trim fell off the 1st week! Interior squeaked and rattled, and the drivetrain clunked after 2k miles. 4x4 switch failed shortly after. Front end - ball joints, struts, hub bearings - all failed between 38k-50k. Engine started burning oil at 50k. Rear and and transmission failed before 100k. Nothing but problems, and frustration with the piss-poor engineering designed to make you give up. Well, it worked! Nothing on that truck was easy to remove ... except the wheels. They haven't figured out how to screw that up yet. Give 'em time ...   I won't make that mistake again. EVER.   Such fond memories ... https://postimg.cc/K1qf23tS  https://postimg.cc/gallery/X02z64J  https://postimg.cc/gallery/mHSRXZv  https://postimg.cc/gallery/D4mMRfL
    • Different monitors do their test only under conditions specific to that monitor.  you MIGHT find the drive cycle conditions for the monitor that isn't ready on this site: https://lemon-manuals.la/   If it's not there, then it should be on alldata.com for your truck, but it requires a paid subscription.   And you need to know which specific monitor isn't ready.
