Hello GMTucks.com   .   Just bought a 2018 Silverado LTZ Crew Cab Redline Edition , awesome truck and I'm extremely happy with the new 8 speed transmission. Its going in next week for the RC 2.5 Level front & rear , as well as new BF KO2's . Still deciding on which cat back exhaust to install . I was going to wait and order a new 19 Trail Boss , but with the current incentives being offered I figure I'd take advantage of them and create my own Trail Boss with an 18 model .   On a side note one of the first things I added to the truck was my GMTrucks.com sticker :-)    Cheers from Ontario Canada.
  • Like 5
20 hours ago, Paulybee said:
My  New Wrap.
Is it iridescent, or is it just printed to look that way? Either way, looks sharp.
On 7/24/2018 at 4:23 PM, LTeddy said:
Looks nice!!! What kind of lift do you have?
Sent from my SM-N950U using Tapatalk
2.5" Motofab Leveling kit
What steps are those? I'm trying to find something like that, but for a regular cab.
Thanks
It's Actually called Black Chrome holographic
Hey Guys, New to the forum and just wanted to post. this place is great!
Truck is a 2014 SLE Texas Edition
  • Like 9
24254703_1733697953317443_2684595283618089963_o.thumb.jpg.c333ac7f31fa7245a4c4a6024a565617.jpg
37358754_1994785950541974_8092610970062422016_o.thumb.jpg.757651e4b366bbf0d7edbbdcd028db50.jpg
37228329_1992654650755104_4209546658544877568_o.thumb.jpg.8f8b070abbb954ebf5fd4b1a9088f730.jpg
Love the look, looks like a hot wheels.
Get ready for the hate from the “pro” off roaders lol
Lowering a truck is blasphemy apparently.
BadAss! Signed - "Pro Off Roader"
Coming from a "pro offroader" as its supposedly called I think your truck is absolutely perfect!
On 7/30/2018 at 4:08 PM, jegreenwood14 said:
Went down to see my grandparents, and did an obligatory farm loop on the way out
Are those rice fields in the background? Is that mississippi?
Yes, they're rice fields that you see.  No, this is in east Arkansas, about an hour and a half from the Mississippi border.  I have a lot of friends that farm in Mississippi (Greenville, Greenwood, Cleveland) areas.
    jaszr2
    jaszr2
  • Who's Online   6 Members, 0 Anonymous, 528 Guests (See full list)
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
