My 2015 K1500 W/T.  Nitto 285's and Bilstein shocks all around.  I also had it tuned by Black Bear Performance.  Looking to put a camper shell on the back when I get back stateside.
  • Like 3
On ‎8‎/‎20‎/‎2017 at 9:42 PM, spoolindawg said:
Heres my 2017 LTZ
20% over the factory privacy glass all around
275/60r20 ko2's
Awaiting the bilstien 5100s
Any rubbing with those tires before the bilstien's specifically with the stamped steel UCA?  Need new tires but don't want to get new shocks yet.
No rubbing before re the level, you are good to go
This is my 14 SLE with 86K.  Who here named their truck?  Mine needs a name!
Most are named “I spent my kids college fund”
14 minutes ago, Sierra Dan said:
The Wife refers to mine as Black Betty  LOL
Reminds me of the Ram Jam song.
Great song.  Maybe I’ll name mine “Bonzo” after John Bonham.
After seeing the edit on your photo…the appropriate name would be “Rudolph”….as in Rudolph the red nosed reindeer!
  • Haha 1
Rudy!  Lmao
  • Haha 2
My 2108 Sierra SLT. Only had time to get it tinted and install a bed cover. Leveling Kit and new AT tires coming soon! Need to figure out how to get rid of the black apron on the front, it only kills my ground clearance on the farm when I hunt.
    AidenVorpagel
    AidenVorpagel
  • Who's Online   3 Members, 0 Anonymous, 1,307 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
