Mostly stock, for now...
Doppelgänger...almost
My 2015 Double Cab LT Z71. 20% tint in the rear windows, 35% front tint. 2" leveling kit in the front with 275/70/R18 KO2s. Also got a Line-X bedliner. Absolutely love it.
My 2015 Double Cab LT Z71. 20% tint in the rear windows, 35% front tint. 2" leveling kit in the front with 275/70/R18 KO2s. Also got a Line-X bedliner. Absolutely love it.><a href=https://www.gm-trucks.com/forums/uploads/monthly_2018_08/20180828_170514.thumb.jpg.139ca84a70bef797ef2971f1216c119f.jpg' alt='20180828_170514.thumb.jpg.139ca84a70bef797ef2971f1216c119f.jpg'>
While searching for my CPO, I ran across exactly one in green. It was on my Top 10 list, but lacked posi/G80 and had 3.08 gears.
Your truck looks great.
Thanks man! I love the green you really dont see many around, i had a green 06 Sierra that I had to part with when the economy tanked in 2010ish and when I found this one back in January it seemed meant to be!
Kind of crappy pics but here's my 14 all terrain. Plans of upgrading to a 4.5in Zone lift & 35s on the stock 20s.
@Sierra Dan not a negative thing to say about them. Just an all around awesome tire. They're quiet as hell and personally love the look of them. Highly recommend!
  • Thanks 1
On 8/28/2018 at 12:23 PM, ncukfan said:
My 2108 Sierra SLT. Only had time to get it tinted and install a bed cover. Leveling Kit and new AT tires coming soon! Need to figure out how to get rid of the black apron on the front, it only kills my ground clearance on the farm when I hunt.
For the front valence just get under there and you'll see maybe 10 screws holding it up. Easy just a little time consuming. Looks so much better without it imo.
Greetings from Dubai! I bought a few weeks ago my 2018 5.3 Crewcab Midnight Edition with Z71 package, 50% tint, and Bakflip MX4 bed cover. Its my first Chevy in my 30 years of buying history, and can say I am impressed with the ride and build quality. I did on this forum a lot of research before buying;
it was very helpfull reading all the posts.
I do not plan any modifications right now, other than removing the lower airdam; I like the truck as it is.
Edited by Silverado_DXB
  • Like 3
  • Thanks 1
2014 Silverado 1500 with 2.5in motofab leveling kit and 35x12.50r18 Mud Tires.0cacb6eee6287c0fee129dafaa53450d.jpg8915c298e8b80d1a56ea03422706c023.jpg
Sent from my SM-N950U using Tapatalk
Based on your truck, which looks great, I think I’m gonna like my truck on stock wheels and 33’s.
Just gotta wait for the leveling stuff to arrive.
Based on your truck, which looks great, I think I’m gonna like my truck in stock wheels and 33’s.
I’ve always liked vehicles that look stock at a glance, but have cool surprises the closer you look.
    RangerRick17
    RangerRick17
  • Who's Online   5 Members, 1 Anonymous, 600 Guests (See full list)
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
